Микроконтролер
OP #6586830
Hello,
I own a Murphy Richards bread bakery. The motor and heater control board
is damaged. I looked for an option to get a new one and replace the old
one, but it turned out to be problematic. Hello,
one, but it turned out to be problematic. If anyone can guide me how to
procure is the easiest way to solve the problem. The other option is to
repair the same board. History: First the motor capacitor was damaged,
which I replaced with the same data. The machine worked perfectly for
about a month. Then suddenly there was a pat-pat with light smoke and an
alarm sounded, and the screen read EE1, at which I immediately turned
off the machine. I inspected the board and it turned out that the relay
for the heater remained constantly on and the heater heats up to a very
high temperature, the contacts are obviously stuck, and I replaced it.
When the screen starts, it displays EE1 again and beeps. Nevertheless, I
let it work to check the operation of the heater. Now the heater does
not turn on. Probably the problem is in the relay control. The data is
in the attached photos.
I hope someone helps.
OP #6586831
Hello,
about a month. Then suddenly there was a squeak of light smoke and a
beep sounded, and EE1 appeared on the screen, and I immediately turned
Guest #6586899
A schemtic of the electronic side would be helping us (me and all
others)..
Do you have that ? Murphy Richards bread bakery: which model ?
What says Google or others for a schematic search ?
Guest #6586936
Check the Termostat (or thermosensor) ..and wires and connectors....
And check if there is a overtemperature -switch or -fuse!
I guess your overtemperature-fuse has tripped.
Guest #6587032
Timeline - I turned on the machine and loaded the products. in the first
phase of stirring, about five minutes after the turn-on, a fault alarm
went off and the motor also stopped rotating. I disconnected from the
network immediately. I checked the board for burns, but they were not
visible. I carefully turned on the machine and at the alarm signal I
started the program. The engine was running and the heater immediately
started heating up strongly, which is not normal. It turned out that the
heater relay is stuck. After replacing the relay, the heater does not
switch on.
Хронология- включих машината и заредих с продуктите. в първата фаза на
разбъркване, на около петата минута от включването пат-пат и се включи
аларма за повреда, като моторът също спря да върти. Изключих от мрежата
веднага. Проверих платката за нагорели места, но  не се виждаха такива.
Внимателно включих машината и при сигнал на алармата стартирах
програмата. Моторът работи, а нагревателя започна веднага да загрява
силно, което не е нормално. Оказа се, че релето на нагревателя е
залепнало. След смяната на релето, нагревателя не се включва.
Start a new thread
