Stabilock 4031
OP #6576858
Good evening Forum,
I am in pose of 2 stabilock 4031 an exit works very well the second with
an error of the modulator fm I cross the cards all ok, the failure is
found in the frequency modulator board around the ic pll mc145106fn pllc
the problem I do not not the diagrams of this card (461 457 08) after my
measurements on the PLL pin 3 (end) 362.545mhz, pin 4 (Oscin) 1.650mhz
pin 8 (Detout) not stable voltage varies a lot, SELF CHECK led lights
up. If not assard someone who could help me with the documentation
thank you.
B.ANTONIO
Guest #6577706
Good evening,
 Thank you for your answer the capacitors I all replaced, for the
service manual I download in another source, the problem in the fm
modulator module there is a card that does not correspond with the
diagram it is another version, the problem  of the failure the pll does
not lock the voltage varies not stable.  Greeting
B.Antonio
Guest #6585887
Hello,
I found the broken coil l6 cut 10uH + GL4 GL5 diode, it is found in the
FM-Modulator 217 031s card in the FREQUENCY MODULATOR board in the RX FM
point 8 line.
the problem is the reference of the coil what type can I use?
have a good week-end
Antonio
Start a new thread
