Initializing simulation with data from ILA
Guest #6554322
• ▲ useful
▼ not useful
I'm looking for a way to assign (or change) certain values to (of) my
signals during a VHDL simulation. For example I'd like to pause the
simulation, change the values of my state machine and continue with the
new values. Is that possible?
I'm aware that you can give signals initial values, however, these
values are deleted during reset. Furthermore it would mean that I had to
change all of my VHDL sources - something I'd like to avoid.
What I actually try to to is to investigate the behaviour of a state
machine I implemented in an FPGA when I feed in the data from my ADCs.
The system is not behaving in the way I wanted, so I used the integrated
logic analyzer from Vivado to store the ADCs samples I got + the state
variables of my control system. I now would like to recreate the exact
same situation in the simulator to see what is going on in the control
logic.
Any ideas?
Guest #6555434
• ▲ useful
▼ not useful
That will do the job I guess, thanks a lot. Unfortunately I have to use
this from the tcl console and can't use it in the VHDL testbench
directly (apparently Vivado doesn't support the force release keywords
from VHDL 2008) but it will suffice.
  • [vhdl]VHDL-Code[/vhdl]
