Help me with this robin subaru generator AVR
OP #6425542
Can someone please help me reverse engineer this old (Robin subaru
generator avr) because i want to build the entire pcb, i already reverse
engineer the board with Sprint-Layout my problem is with some of the
components values used in the board?
Guest #6430880
Benjamin B. wrote:
> I need to know the Zener values
> No one ?
What the fuck do you expect? We can't measure then Zener values, but you
can do it...
Remove the epoxy coating using a appropriate solvent, solder out the
Zeners and measure.
May be, you're a little bit more lazy than you should...
OP #6431051
I am here asking experienced people to help me if they can, I tried to
remove the items but it was broken and according to my research there is
no way to remove the glue.
And about being lazy, I am not an electronics engineer, and I already
get the values of some components but I am not 100% sure of the values
and I will upload the Image, In the end sorry for angering you.
Guest #7105342
I used a universal AVR available on aliexp ... But the problem is that
this generator does not want to wake up itself. It can be done as an
additional coil used behind the cutter. Power connection from this coil
is on. Bridge rectifier for test procedure. Perform the function also
connected to the control function. During the under load tests, we
claimed that it was tested on a trial basis, and after firing it it woke
up with no problem.
Alternatively, excitation can be created by meticulous magnesia on
through as done in Chinese.
#7361982
I've got an old Robin RGD 351, AVR is missing and I'd like to get a new one. Have you been able to reverse engineer it? Maybe I could build one, but it would be better to find one as I'm not too good with electronics yet. Thanks
Start a new thread
