Getting to the Root Cause of BGA Assembly Problems
Guest #6413377
• ▲ useful
▼ not useful
When potential process defects begin showing up underneath BGAs in
electronic assemblies, there are numerous failure analysis tests that
can be used to troubleshoot process problems.
In determining potential assembly defects at BGA locations.  The first
level of BGA failure analysis is visual inspection with the aid of a
microscope or borescope.  The next level of visual inspection, which
may, in some cases, allow for inspection into the third row of the area
array device, will be via a borescope. This visual inspection tool is
especially useful when neighboring components are only a few millimetres
from the perimeter of the BGA.
In addition to these visual techniques, X-ray imaging will also help to
diagnose and troubleshoot the process being investigated.  There are
numerous anomalies and defects that can be seen through the use of X-ray
inspection. This is followed by closer, higher magnification inspection
of “areas of interest.”  Shorts and violations of minimum electrical
clearance are common problems which can be measured and found using
X-ray inspection. Besides, Dye and pry testing is a relatively simple,
cost-effective destructive method for testing the integrity of the
solder joint on a BGA package. The method does not require any high-end
capital equipment instead of relying on generally available
investigative or production tools. Testing of this type can be
outsourced to failure analysis test labs or be done by the user.
If no failures are indicated by the dye, then other test methods such as
cross-sectioning, acoustic microscopy, and EDX or SEM analysis may be
the next steps in finding a root cause in the BGA solder joint failure
analysis.
source smartronics
  • [vhdl]VHDL-Code[/vhdl]
