Forum: FPGA, VHDL & Verilog Double Data Rate Serializer verilog
von Atalin (Guest)
Hi! I want to write the code for a serializer which works both on rising
edge and falling edge of the clock. The idea is to write two registers,
one for the even bits and the other one for the odd bits, and then a MUX
which send out the data. Moreover, I have a control signal called LOAD:
when LOAD is high, I want to load the data into the two registers. The
problem is that the even bits are not loaded into the register and I do
not know why because I wrote the same piece of code both for the odd
bits and the even ones. Can anyone help me? Thank you very much! The
code is hereinafter.
module serializer (data_in, send, clk, load, rst, data_out);
input wire [11:0] data_in;
input wire send, clk, load, rst;
output reg data_out;
reg [7:0] temp_data_out_even;
reg [7:0] temp_data_out_odd;
integer i;
integer j;
always @ (posedge clk)
begin
  if (rst) begin
    data_out <= 1'b0;
    temp_data_out_odd <= 8'b00000000;
  end
  else if (load) begin
    temp_data_out_odd <= 8'b11000000;
    for(i=0; i<6; i=i+1)
      temp_data_out_odd[5-i] <= data_in[11-i*2];
  end
  else if (send) begin
    data_out <= temp_data_out_odd[7];
    temp_data_out_odd <= {temp_data_out_odd[6:0], 1'b0};  // Shifting phase
  end
end
30
31
always @ (negedge clk)
32
begin
33
  if (rst) begin
34
    data_out <= 1'b0;
35
    temp_data_out_even <= 8'b00000000;
36
  end
37
38
39
    for(j=0; j<6; j=j+1)
40
      temp_data_out_even[5-j] <= data_in[10-i*2];
41
  end
42
43
    data_out <= temp_data_out_even[7];
44
    temp_data_out_even <= {temp_data_out_even[6:0], 1'b0};  // Shifting phase
45
  end
46
end
47
48
endmodule //end module serializer
The testbench is the following
`include "serializer.v"
`timescale 1ns / 1ps
module serializer_tb();
// Declare inputs as regs and outputs as wires
reg [11:0] data_in;
reg send, clk, load, rst;
wire data_out;
reg [11:0] reg_sipo;
reg check;
integer i;
// Initialize all variables
initial begin
  clk = 1;       // initial value of clock
  rst = 1;       // initial value of reset
  load = 0;
  send = 0;
  #15 rst = 0;   // De-assert the reset
  forever begin
    foreach(data_in[j]) data_in[j] = $urandom;
    #13 load = 1;
    #20 load = 0;
    #5 send = 1;
    #20          //header
    for(i=0; i<12; i=i+1) begin
      #5 reg_sipo[11-i] <= data_out;
30
      end
31
    #10 send = 0;
32
    if(reg_sipo == data_in) check = 0;
33
    else check = 1;
34
  end
35
end
36
37
// Clock generator
38
always begin
39
  #5 clk = ~clk; // Toggle clock every 5 ns - 100 MHz
40
end
41
42
// Connect DUT to test bench
43
serializer U_serializer (data_in, send, clk, load, rst, data_out);
44
45
endmodule
von Alexx (Guest)
I am not really a verilog user but can you write on a signal from two
different processes? in VHDL you cannot.
von -gb- (Guest)
You should could use a DDR IO Primitive from the FPGA Vendor. Like ODDR2
from Xilinx.
But ... no, not write from two processses, but read.
Registers A for rising edge and B for falling edge. And some logic which
provides new data for BOTH registers.
So the logic (with whatever clock) provides new data for both registers.
And sets a data valid signal.
With rising edge logic, the data valid signal is detected and the
provided data is written to reg A.
With falling edge logic, the data valid signal is detected and the
provided data is written to reg B.
von Ian Tseng (Guest)
I think
Should be
      temp_data_out_even[5-j] <= data_in[10-j*2];
10-i*2 => 10-j*2
