How powerful is Verilog at using parameters to specify designs?
#6412983
I have a design in mind that would fit in this skeleton:
module xyz ( result, leftOp, rightOp);
parameter  integer nmBits = 1;
localparam integer highBit = nmBits - 1;
output             result;
input [ highBit:0] leftOp;
input [ highBit:0] rightOp;
endmodule
The way (xyz) is designed, this module would work differently for
different values of (nmBits), but in a way that can be precisely
defined. In fact, I'm seriously thinking of writing a Java program that
takes (nmBits) as an input and produces a parameterless verion of (xyz)
for that version of (nmBits). So I'm wondering, is it a true statement
that, if one can write such a Java program to produce the equivalent
(parameterless) Verilog code for any given set of parameters, one can
also write Verilog code with parameters to do the same thing?
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
