warning: Static variable initialization requires explicit lifetime in this context
OP #6409185
• ▲ useful
▼ not useful
I've got a Verilog compilation complaint that I've been able to isolate
in a stripped down version of my code:
module expLif ();
parameter  integer nmBits  = 1;
localparam integer highBit = nmBits - 1;
output             lssThn;
input [ highBit:0] leftOp;
input [ highBit:0] rightOp;
typedef enum { CORNER, E_LEAF, N_LEAF, SIDE, E_INTERIOR, N_INTERIOR } nodeType;
typedef struct packed
{ nodeType ndType;
   integer inLow;
   integer inHigh;
   integer out;
} node;
localparam integer nmNodes  = 2 * nmBits - 1;
localparam integer nmLevels = $clog2( nmBits) + 1;
localparam integer [ nmLevels:0] bases;
initial
begin
  integer lvl;
  integer pwr = 1;
  bases[ 0]   = 1;
  for (lvl = 1; lvl <= nmLevels; lvl = lvl + 1)
  begin
    bases[ lvl] = bases[ lvl - 1] + ((nmNodes + pwr >> lvl << 1) - 1);
30
    pwr       <<= 1;
31
  end
32
end
33
34
endmodule
The actual complaint when I try to simulate this with Icarus is:
D:\Hf\Verilog\Unpacked\Src\Common>\Icarus\bin\iverilog -g2009 -o expLif.vvp expLif.sv
expLif.sv:19: syntax error
expLif.sv:19: error: syntax error localparam list.
expLif.sv:25: warning: Static variable initialization requires explicit lifetime in this context.
I want value (pwr) to be successive powers of two each time I go through
one iteration of the loop. Can anyone tell me why this code doesn't work
and/or what I need to do to fix it? Thanks in advance for any
suggestions you can give me.
OP #6410182
• ▲ useful
▼ not useful
Klakx: "I think the error is more important. Try this localparam integer
bases [ nmLevels:0];" I'm fine with fixing the error before dealing with
the warning. But I
made the change you suggested:
module expLif ();
output             lssThn;
{ nodeType ndType;
   integer inLow;
   integer inHigh;
   integer out;
} node;
localparam integer bases [ nmLevels:0];
initial
begin
  integer lvl;
  integer pwr = 1;
  bases[ 0]   = 1;
  begin
30
    pwr       <<= 1;
31
  end
32
end
33
34
endmodule
and then when I used Icarus to attempt to simulate it I got:
E:\Hf\Verilog\Unpacked\Src\Common>\Icarus\bin\iverilog -g2009 -o expLif.vvp expLif.sv
so the change you suggested doesn't appear to have fixed the error. Do
you have any other ideas on what might be causing the error and/or how I
can fix it? Anybody know what I'm doing wrong here?
  • [vhdl]VHDL-Code[/vhdl]
