<html><head><title>TigerSBC overview</title></head><body>
Welcome to the user-defined TigerSBC DDE (Disintegrated Design
Environment).<br>
TigerSBC is fun to program, and if you like being in the driver's seat,
this machine might be for you.
<br><br>
TigerSBC_yyyy_mm_dd.zip is a snapshot of experimentally verified
hardware and software source files,
for free use at one's own risk.
<br><br>
Many Python3 and Verilog source iterations led to this snapshot.
Mistakes were made along the way, and corrected.
(See doc/koans.txt.)<br>
It is hoped that users will enjoy making and correcting their own
mistakes, and sharing their successes.
<br><br>
This DDE implements a 12-bit 36 MHz lab/maker computer on a Lattice
iCE40-HX8K FPGA Breakout Board, and its assembler.
<br><br>
Why 12 bits versus industry norms?<br>
1) more powerful than 8 bits<br>
2) simpler and faster than 16/32/64 bits<br>
3) object code is compact, minimizing memory overhead<br>
4) naturally matches popular 12-bit SPI ADCs and DACs for the lab/maker
computer mission
<br><br>
TigerSBC's performance and code-density apparently rivals commodity
MCUs.
The entire 4Kx12 code/data/io memory space is on-chip.
All reads and writes complete in one (1) clock cycle.
<br><br>
5V0 power and the host interface are provided via USB.
Memory-mapped io includes a 28-bit signed multiplier/accumulator and a
48-bit timer.
Efficient 12-bit bit-banging parallel io, and an 8-bit mode 0 master SPI
interface are also provided for 3V3 user io.
doc/EB85_pins.txt summarizes user io on the J2 and J4 2x20 0.1 inch
(2.54 mm) pitch connectors.
<br><br>
Software libs and apps include Fast Fourier Transform and convolution
DSP amenities.
A 512-point complex FFT takes ~13 ms.
An 8-point complex FFT takes ~78 us.
<br><br>
Tigerasm is written in Python3, providing a powerful syntax and
interactive user interface.
New users should first learn how to program their own Tigerasm libs and
apps for the existing hardware implementation.
Experienced users who speak Verilog might mutate the hardware as they
see fit.
<br><br>
The Tiger CPU executes all (16) instructions in one (1) clock cycle. See
Verilog/Tiger_opcodes.v for the summary.
The data and program counter stacks are register arrays with RPN
arguments and results (smells like, but is not Forth).
Unique instruction fetch logic frequently saves clock cycles. See
doc/instruction_fetch.txt for the commentary.
<br><br>
Tigerasm macros and procedures provide additional (multi-clock)
operators.
Flagship examples are in lib/fft.py and apps/fft_test.py.
A simple example is in apps/hello.py.
<br><br>
A minimal DDE to use TigerSBC as-is requires:<br>
* TigerSBC_yyyy_mm_dd.zip<br>
* a Lattice iCE40-HX8K Breakout Board and included USB cable, and a
reset switch (see doc/reset.txt)<br>
* a text editor (e.g. Notepad++)<br>
* Python3 for the Tiger assembler<br>
* a serial terminal emulator with raw file send capability for
communication via USB/UART at 115200,8,n,1 (e.g. Tera Term)<br>
* Lattice Semiconductors Diamond to burn the existing FPGA configuration
(pre-generated by iCEcube2 on the author's host)
<br><br>
A full DDE to create your own hardware mutations also requires:<br>
* Lattice Semiconductors iCEcube2 for FPGA design<br>
* Icarus Verilog for new module design and simulation
<br><br>
Getting started (Win10 example, Linux translations are
straightforward):<br>
0) Unzip TigerSBC_yyyy_mm_dd.zip to your desktop and study
doc/overview.html (this file).<br>
1) Obtain the requisite hardware and install the requisite software
(punt to vendor doc).<br>
2) Rename asm.cmd.txt to asm.cmd.<br>
3) Rename sim/ivsim.cmd.txt to sim/ivsim.cmd.<br>
4) Connect your board (with closed reset switch connected on J2) via
USB. Be curious about which COMx the OS decided to assign.<br>
5) Launch Diamond to burn your board as a TigerSBC with the USB/UART app
loader:<pre>
select Create a new blank project, click OK
under the Device Family heading, select iCE40
under the Device heading, select iCE40HX8K
under the Operation heading
select Access mode: SPI Flash Programming
select Programming file: FPGAburn/TigerSBC_bitmap.bin
click OK
click the Program icon
if failure, try hot-switching to another USB physical connection
and retry (this happens if you have more than 1 board)
on success, quit Diamond without saving the configuration</pre>
6) Launch a command prompt and enter these lines to test the
assembler:<pre>
cd Desktop/TigerSBC
asm apps/hello.py
save_app('apps/hello.app')
(optional: investigate the suggested Python3 amenities)
exit()</pre>
7) Launch the serial terminal emulator, configured 115200,8,n,1 on the
currently-assigned COM port:<pre>
close the reset switch
open the reset switch, you should see
Tiger is ready to load...
raw file send apps/hello.app
you should now see:
Tiger is ready to load...done
Hello, world!
the red led D7 on the board should be blinking</pre>
For hints on writing your own apps, see FPGAburn/appload.py, lib/*.py,
apps/*.py, and Tigerasm.py.
<br><br>
Tigerasm.py defines a 2-pass assembler that reads in source scripts via
the include('filename') core procedure.
In the first pass, new symbols and (explicit) forward references are
collected.
In the second pass, the final object code image is generated, ready to
be saved to disk as an app (or a hex) file.
<br><br>
Although based on Python3, indentation in Tigerasm source is purely
cosmetic.
The examples in this snapshot reflect the author's preferred style.
<br><br>
All Tigerasm symbols are global and must be unique. The order of
encounter in source is important.
If an error occurs, inspect includes to see the list of included
source files.
The last file in includes is where the error was detected, but not
necessarily the root cause.
Python3 dir() and globals() list the known symbols for further
inspection.
Tigerasm dump_ram(start_adr, end_adr) shows raw hexadecimal object code
and data.
<br><br>
Typical Tigerasm libs and apps inherit the following host interface
procedures from FPGAburn/appload.py:<pre>
lbl('rx') # -> d
# await zero-extended 8 lsbs from USB/UART
lbl('tx') # d ->
# transmit 8 lsbs of d to USB/UART
lbl('tx_ascii') # adr ->
# transmit a zero-terminated ascii string to USB/UART</pre>
Those interested in Verilog will find hints in Verilog/*.v.
Edit ram.v to correct the absolute reference to FPGAburn/ram.hex (the
USB/UART app loader initial memory image).
iCEcube2 might then be used to build a new TigerSBC project for the
board.
(Arcana: this snapshot required using the <right-click>Synthesis Tool:
Synplify Pro option.)
Hardware mutations require followup changes to Verilog/TigerSBC.pcf and
the io addresses defined in Tigerasm.py.
<br><br>
To try the Icarus Verilog simulator, launch a command prompt and enter
these lines:<pre>
cd Desktop/TigerSBC/sim
ivsim spi</pre>
The simulation display was also saved to spi.log for posterity,
try:<pre>
copy spi.log con</pre>
For further consideration:<br>
This single-core implementation left most of the iCE40-HX8K FPGA
resources available.<br>
Future mutations might explore parallel execution of multiple cpu+ram
cores and their io interfaces.
<br><br>
Have fun being in the driver's seat!<br>
Myron!Plichota@at#gmail$dot%com
</body></html>
Guest
#6398480
well, just this ZipArchive out of nowhere? No Code repository (git or the like) yet? How would you deal with contributions? Publicly accessible search engines do Not (yet) Know about this... (or it's my lack of SE-mojo) But at least it's a start :-)
Guest
#6398555
No wonder that search engines do not know about this since it was published just hours ago out of "nowhere". For the time being, new users should evaluate the existing publication. In the event of an active TigerSBC community emerging, we can discuss via email (as was done prior to github and sourceforge) how and where to host a "better" collection of resources.
Here is a spectrum analyzer app (spectrum.py) that uses the release libraries.
1 | |
2 | |
3 | |
4 | |
5 | |
6 | |
7 | |
8 | |
9 | |
10 | |
11 | |
12 | |
13 | |
14 | |
15 | |
16 | |
17 | |
18 | |
19 | |
20 | |
21 | |
22 | |
23 | |
24 | |
25 | |
26 | |
27 | |
28 | |
29 | |
30 | |
31 | |
32 | |
33 | |
34 | |
35 | |
36 | |
37 | |
38 | |
39 | |
40 | |
41 | |
42 | |
43 | |
44 | |
45 | |
46 | |
47 | |
48 | |
49 | |
50 | |
51 | |
52 | |
53 | |
54 | |
55 | |
56 | |
57 | |
58 | |
59 | |
60 | |
61 | |
62 | |
63 | |
64 | |
65 | |
66 | |
67 | |
68 | |
69 | |
70 | |
71 | |
72 | |
73 | |
74 | |
75 | |
76 | |
77 | |
78 | |
79 | |
80 | |
81 | |
82 | |
83 | |
84 | |
85 | |
86 | |
87 | |
88 | |
89 | |
90 | |
91 | |
92 | |
93 | |
94 | |
95 | |
96 | |
97 | |
98 | |
99 | |
100 | |
101 | |
102 | |
103 | |
104 | |
105 | |
106 | |
107 | |
108 | |
109 | |
110 | |
111 | |
112 | |
113 | |
114 | |
115 | |
116 | |
117 | |
118 | |
119 | |
120 | |
121 | |
122 | |
123 | |
124 | |
125 | |
126 | |
127 | |
128 | |
129 | |
130 | |
131 | |
132 | |
