LED controlling protocol like WS2812 for more colors
Guest #6387545
Hello,
I need a LED strip where I can control the LEDs individually, but also
have more than 3 color channels like with e.g. WS2812 or the 4 with
SK6812.
I would like to control at least 5 channels (RGB + warm white + cold
white) but in the best case I would want a protocol that can control
even more channels (RGB + warm white + cold white + amber + lime + deep
blue + ...).
Is there already some protocol that has the ability to do that or what
would be the easiest/best way to do that?
Guest
You could just use the chip inside those Neopixels and connect like two
or three of them per lamp, giving you 6 or 9 channels.
The protocol of any RGB lamp just transfers (usually 8-bit) brightness
values, not a color, so youc ould connect any lamp you like.
Guest
Hey,
yes, but are there LED strips that have that functionality?
I would want to just have a reel like a normal LED strip, but have more
control channels for more colors.
Guest
I'd say no.
There are RGBW LEDs with one white, and there are Strips with those.
Then you find Strips with CW and WW LEDs, but those lack RGB.
I've never seen strips with those weird colors you want, even normal
LEDs are hard to get, so you may not even find lamps with that mixture.
Commercially available RGB/CW/WW lamps have separate LEDs for RGB, C and
W, and i guess there's a reason for this... ;)
Guest
There is the ws2811 led driver chip. You can attach any led you like and
cascade as many as you need. Otherwise I see no other solution beside a
discrete build. Take a small microcontroller and an led driver like the
tlc59116 and create your own protocol.
Start a new thread
