How do I declare a packed array in Verilog?
OP #6371301
I've created an (enum) called (color), and included it in a packed
(struct) called (triple), and then created a ten-element array called
(group) in the following code:
module EnStAr ();
typedef enum { RED, ORANGE, YELLOW, GREEN, BLUE, VIOLET } color;
typedef struct packed
{   color clr;
  integer xCoo;
  integer yCoo;
} triple;
triple [ 9:0] group;
endmodule
When I execute the following command I get the following single error
message:
D:\Hf\Verilog\Common>\Icarus\bin\iverilog -g2009 -o EnStAr.out EnStAr.sv
EnStAr.sv:10: Compound type is not PACKED in this context.
Line 10 is where I declare my array. Is this saying my array is not
packed? If so, how do I fix this so that my array is packed? I guess the
bottom line is, how do I change this file so that Icarus' simulator will
compile it without error messages?
Guest #6375077
Could you solve the Problem? Your code compiles w/o problems in Questa.
Maybe icarus cannot deal with packed arrays of complex elements. Do you
really need a packed array here? Otherwise try
triple group [9:0]
OP #6376344
Vancouver: "Do you really need a packed array here? Otherwise try /
triple group [9:0]". I tried that and it compiled without any complaint
at all. Thanks! So I have to pack my (struct), but having done that I
can't pack an array of that (struct)? Why is that?
Guest #6377153
To be honest, I dont know. Generally it is supported by SV, but it seems
Icarus does not.
Anyway, a packed array only makes sense if you want to assign the
complete array from a large bit vector for example. In this case, the
array must be "dense", as the bit vector is. If the array elements are
addressed via array index only, there is no need for using packed
arrays.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
