identify the µC of a LCU?
OP (Company: Schaeffler Group) #6348318
I would like to know how to identify the µC of an automotive LCU or its
performance (frequency, memories,...). Is there a way to do that without
a tear-down? If a tear-down is necessary, how to proceed in case the
device is not marked? Or, how to proceed in case the µC is a bare die?
Thank you.
PS: I am just a mechanical engineer. Hence, please explain it in "Sesame
Street style"
Guest #6394875
Without tear-down, your only hope is to grab schematics/tech doc.
For unmarked chip, or bare die (under an epoxy blob), you can only
de-cap (using very hot highly concentrated nitric acid) and a very good
microscope using polarized light. Then you need to identify the die....
Good luck !
The next problem will be the software embedded in the chip. Most chips
have built-in safety fuses preventing reverse engineering.
If you want to have an overview of this impossible task, visit Ken
Shiriff's blog (www.righto.com). This should show you the amount of
money you need to invest...
Start a new thread
