Hello Everyone and the Toshiba T2295A Chip
OP (Company: Puget Souind Energy) #6339910
Hello:
I'm an electrical engineer in PSE's facility services group and don't
have the opportunity much of asking electrical questions.  I like to fix
things and found mikrocontroller.net with my topic of interest but it
isn't in English.  I wish I had the English version of that topic that
discussed the Toshiba T2295A chip.
I don't see rules for postings so kindly let me know if this appropriate
for this forum/web site.
The T2295A chip drives the tachometer meter on a scooter that is 37
years old.  The meter works with, say, 1.25 VDC at it passing 12.5 ma,
so the meter's internal resistance is 100 ohms.  This is with the meter
out of the circuit.  Meter works as a voltmeter and is fully functional,
though labeled in RPM.
Looking back into the PCB and capacitor (driving the meter) I see 200
kohm, but the meter always has 0 VDC in sitsu.
Is there discussion on mikrocontroller.net on how it works, expected
voltages at the ZIP-9 chip leads, back sheets in English as
alldatasheets.com doesn't list it?
The PCB schematic comes from mikrocontroller.net.
Later:  You know, I think I got it working.  I saw VCC and IN and they
were swapped.  Probably all these years by the original equipment
manufacturer.  Looking at the schematic I got from mikrocontrollers.net
in a language I didn't understand, yet seeing those two words/symbols on
the drawing helped me just minutes ago.  Swapped the yellow with the
black wires to the Honda Flush tachometer.
Guest #6612620
Good afternoon sir.  Did you ever find a datasheet for this T2295A?  I
have the same problem.  The circuit diagram you provided matches the
circuit board that I removed from my tachometer, but I am getting no
voltage out to the meter.  The tachometer functioned correctly for 20
years.  Then failed.  All the components look and measure okay, so I
want to remove the T2295a and pin check it.  But I can't fond the
datasheet anywhere.
Thanks,
Martin
Canada
Guest #6612885
No, never got a pinout of the chip.  Wiring was actually correct and for
some reason the tachometer works in the scooter.  Someone told me to
replace the largest capacitor but I didn't do that.  Did you?
Guest #6614092
Hi, thanks for the fast reply.
I have not replaced any components yet.  On the test bench I can measure
the pulses entering the chip @ pin 2, but no voltage out on pin 6.  But
I am very new to circuits and diagrams, so I may be off base.  The short
of it - I detached the the board from the rest (coil / needle) and when
I power the needle portion only, it works.  When connected to the board,
does not work.  I am putting 1 kHz 12 volt pulses in.  Those drop across
the R1 resistor, so they are about 2 volts at the pin into the IC.  I
assume that's correct - the resistor is good, and there is nothing else
between.  After that...nothing out.
I can order a chip off eBay for about 5 bucks.  I might just swap it out
and see if that works.  I might try changing that cap too.  Parts are
cheap.
Stay healthy!
Thanks for the tip, and BTW, the diagram you posted was really helpful!
Martin
Guest #6620129
Hi, I changed that cap (6.3v / 1000uF).  The tach is working again, so I
guess that was the problem.  Cheap fix.  Cap cost $1 at the local
electronics supply store.
Thank again!
Martin
Guest #6620284
Hey, that is great!.  I would have to thank whomever told me about the
capacitor replacement. David Babbitt
Start a new thread
