q'n'd corona lathe
Guest #6251523
Hi'all, I needed a bunch of soft wood discs whose dimensions doubly did
not match my hole saw,so a make-do lathe was called in order. The centre
whole had to stay below 4mm and none of my cheap hole saw OD was close
enough to what I needed, that centre bit was 6mm anyway.
It's a wreck of a battery powered drill mounted onto a wooden board
scrap by means of an angle plate. Power comes temporarily from a random
IT PSU off the junkbox with 12V being below the nominal 18V of this
Mabuchi RS-550 "engine", but it did the trick.
I clamped a section of fence post angle iron together with the drive in
my vise so I had a tool rest for the chisel.
It wobbled way to few rpms and the M4 threaded rod was plenty weak for
having no tailstock supporting the far end but with adequate care, some
curses and prayers the job went fine.
Guest
uhm'kay
same exact result can be had with a drill mounted
in a horizontal drill holder as depicted.
those are usually meant for wirewheels or grindingstones alright.
But I used mine and my ac drill to cut rod
round or chamfere rod ends etc..
(protruding end supported in a bearing.. reduces the wobble ;))
And while I think every one of us did some rudimentary turning in a
drill chuck at least once or twice..
I wouldn't want to go as far to call that even a make-shift lathe.
Since it got the job done, kudos to you sir;
but calling it a share worthy make-shift lathe is kind of a stretch
IYAM.
just sayin'
'sid
Start a new thread
