width mismatch in assignment error for barrel shifter
Guest #6219459
I am learning FPGA prototyping by VHDL examples by myself. Currently I
encountered an error when I ran synthesis on the attached vhdl file.
The error shows shows "width mismatch in assignment; target has 8 bits,
source has 16 bits on line 57". Line 57 is listed as follows:
b <= a(shiftAmt-1 downto 0) & a(2**WIDTH - 1 downto shiftAmt);
shiftAmt was defined on line 47 as:
signal shiftAmt : integer := to_integer(unsigned(amt));
Can anyone tell me what causes the error and how I can fix it? Thanks.
Guest
You are assigning amt to shiftAmt only at signal declaration, but amt is
coming from a port, so that will not work.
Instead define the signal as:
signal shiftAmt : integer;
and add this assignment to the architecture:
shiftAmt <= to_integer(unsigned(amt));
I haven't tried synthesis with it, but at least modelsim works with it.
In any case, you should consider using the build in shifting functions
like sll, srl, shift_right, ror, ...
Guest
Thank you so much for your swift reply. I am beginner for both VHDL and
FPGA. The barrel shifter is a project in the textbook. I tried your way,
but the width mismatch error still exists. I attached the modified file.
Is it possible a Vivado error instead of VHDL error? Thanks.
Guest
You are right, as the assignment is not constant, synthesis may not
recognize that it needs to build a multiplexer there. Quartus does also
not like it, so it's not just Vivado.
Here is a possible solution using a process:
process (a, shiftAmt)
begin
  b <= (others => '0'); -- to prevent latches from bein built
  for i in 0 to 2**WIDTH - 1 loop
    if (shiftAmt = i) then
      b <= a(i-1 downto 0) & a(2**WIDTH - 1 downto i);
    end if;
  end loop;
end process;
This implements the multiplexer required by choosing based on the
shiftwidth.
Another possibility would be something like that:
gshift: for i in 0 to 2**WIDTH - 1 generate
begin
   b(i) <= a(2**WIDTH - 1 - shiftAmt) when ((shiftAmt + i) > (2**WIDTH - 1))
   else a(shiftAmt + i);
end generate;
Which does exactly the same by assigning the correct source bit to the
target bit.
Not sure if the correct bit is picked, was just a short test if it
builds.
I still would just write like that:
b  <= std_logic_vector(unsigned(a) ror shiftAmt);
As it's easiest to read and hard to build an error into it.
All 3 variantes require exact same amount of ressources.
Guest
Thanks again. I tried all three solutions. Both solution 1 and 3 works
well. But I had trouble to run the simulation for solution 2. It seems
the simulation error is also related with shiftAmt in the index of an
array. I applied the method in your solution 1 to modify the solution 2
and the error was gone. I listed the codes as follows:
-- solution 2:
shiftAmt<= to_integer(unsigned(amt));
process(a, shiftAmt)
begin
    for i in 0 to 2**WIDTH-1 loop
            for j in 0 to 2**WIDTH - 1 loop
               if j < ( 2**WIDTH - shiftAmt) then
                b(j) <= a(shiftAmt + j);
               else
                b(j) <=a(j - 2**Width + shiftAmt);
               end if;
            end loop;
        end if;
    end loop;
end process;
Now I am still confused when the error will happen. It seems no variable
is allowed in the index of an array. But index i is also a variable,
right?
Guest
Sorry to not made this clear:
Solution 2 is to be used outside of a process.
Solution 3 can be used inside and outside of a process.
Solution 2:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.all;
entity barrel_shifter is
   generic (WIDTH: integer := 3);
   Port (
    a : in std_logic_vector(2**WIDTH - 1 downto 0);
    amt : in std_logic_vector (WIDTH-1 downto 0) := (others => '0');
    b : out std_logic_vector( 2**WIDTH - 1 downto 0)
    --b: out integer
end barrel_shifter;
architecture Behavioral of barrel_shifter is
    signal shiftAmt : integer := 0;
begin
   begin
      b(i) <= a(2**WIDTH - 2 - i + shiftAmt) when ((shiftAmt + i) > (2**WIDTH - 1))
   end generate;
end Behavioral;
It's still working in sythesis (sorry, only tried quartus as i don't
have Vivado installed) and modelsim with this simple testbench:
library IEEE;
use IEEE.std_logic_1164.all;
entity tb is
end tb;
architecture Behavioral of tb is
begin
   dut: entity work.barrel_shifter
   port map
      a   => "00000111",
      amt => "010",
      b   => open
end Behavioral;
Guest
My fault. The simulation error happened because I didn't initialize
shiftAmt to 0. Now it works well in Vivado too.
Thank you so much for your help. I am so lucky to find such a great
mentor like you in the forum!
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
