modelsim dont work
Guest #6211995
the program supposed to count the number of '1' in a given 32bit input
library IEEE;
use IEEE.std_logic_1164.all;
entity one_cnt is
port( serial_bit_input : in std_logic_vector (31 downto 0);
      result            : out  integer range 0 to 32) ;
end;
architecture behave of one_cnt is
signal cnt : integer range  0 to 32;
begin
process(serial_bit_input)
begin
cnt<=0;
  count_loop : for i in 31 downto 0 loop
    if serial_bit_input(i)='1' then
      cnt<=cnt+1;
    end if;
  end loop count_loop;
result<=cnt;
end process;
end architecture;
as you can see :
* Fatal: (vsim-3807) Types do not match between component and entity for
port "result"
what sould i do?
Guest #6218207
I guess you accidentally compiled the Component template file *.vho
instead of the source code (typically *.vhd oder *.vhdl).
Your code has only 27 lines of code, but the error was reported on line
83.
Little hint:
Your design won't work this way. Try the code bellow...
process(serial_bit_input, cnt)
  variable cnt : integer range  0 to 32;
begin
  cnt := 0;
      cnt := cnt + 1;
    end if;
  result<=cnt;
end process;
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
