Choose hardware component - thyristor - minimum resistance/ voltage drop
OP #6209700
• ▲ useful
▼ not useful
Hello everyone,
I am currently working on a project, where I want to use a thyristor as
a static switch that once turned on stays in its on (conductive) state.
The problem is, that I can't find any information about the thyristors
remaining collector emitter resistance once triggered. The datasheets
don't provide that value. Also no shop provides any sort or filter
option regarding this value. I would like to choose the component with
the minimum resistance/ voltage drop in conductive mode.
I asked a question regarding this topic quite some time ago but it could
not really be solved and now returning to this project I am stuck again.
I hope you can help me.
Thanks a lot :-)
Guest
• ▲ useful
▼ not useful
the voltage drop is with any thyristor somewhere around 1V, the sum of
one BE-equivalent junction and the saturation voltage of the opposite
CE-equivalent junction
The exact value depends on your current, also the doping levels where
there is a trade off between switching speed and voltage
As an example i am refering to the BT145 that i recently used,
https://de.rs-online.com/web/p/thyristoren/4842836/ where datasheet
figure 10 lists the on-state voltage as a function of current
OP
• ▲ useful
▼ not useful
Thanks a lot for your answers!!
Pointing me to the datasheet and telling me what to look for with
"on-state voltage" I could now figure out more what I have to search
for. As you said all thyristors I could find have a voltage drop of
around 1V so it doesn't seem to make sense for me to use them in my 12V
and relatively low current application. I was now thinking about using
alternatively a MOSFET and somehow create a self-holding circuit for it.
My problem in general is that I want to build a one cable solution
meaning the switching MOSFET and its controlling circuit should sit on
the cable that powers (+) the load without any direct connection to
ground despite through the load itself. Can someone think of a way to do
this? Maybe with a charge pump and using the on state resistance of the
MOSFET?
Also please excuse my late reply. I invested some time getting familiar
with LTspice and trying to come up with a solution myself.
I'm looking forward to possible answers :-)
Start a new thread
