Efficient way to store data buffer and transmit it between entities
OP #6193544
I am trying to store data which comes from the output of an entity "A"
(std_logic_vecotr(7 downto 0 bits). Per data transmission the entity "A"
updates it output and may recieve max 64 bytes and store them in Entity
"B" for further processing.
I store the data through a variable std_logic_vector (511 downto 0)   in
Entity "B" and then I parse the recieved buffer to an Entity "C". Is it
ok if I pass the parsed data to an Entity "C" with an output of lets say
std_logic_vector(239 downto 0) or is it better if I just have an output
with a std_logic_vector(7 downto 0) and send the required data per clock
cycle and store it inside a variable?
This is repeated between other entities I have so I dont know if its
better to pass all the bytes directly between outputs or have a 1 byte
buffer output that is updated between clock cycles.
Im not an expert on vhdl so Idk if when I synthesize the code it would
be better to use a 1 byte buffer output or send all the data (1-64
bytes) between entitites.
Best regards
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
