Use example of Intel University program in Intel Quartus - problem with Board support package?
OP (Company: haa) #6191458
I already posted my problem in the german section of
mikrocontroller.net.
As it was a little bit unclear and a lot of content I want to reduce my
concern:
I want to use a example from the Intel FPGA Monitor Program 18.1 and use
it in Quartus 18.1. It is the video example, which creates a blue box on
the HDMI output and writes a littel String with white letters on top of
it.
I want to use it in Intel Quartus environment , do some test-outputs on
my screen and finally add some more Hardware to the Avalon system.
Unfortunately it doesnt work for me as i thought xD:
short file overview:
Project File: DE10_Nano_Computer.qpf
QSYS Konfiguration File: Computer_System.sopcinfo
SRAM File : DE10_Nano_Computer.sof
NIOSII Main: video.c
NIOSII library: address_map_nios2.h
Project includes:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=2ahUKEwiHq8Ha0bHoAhXOsKQKHUu6DdIQFjAAegQIAxAB&url=ftp%3A%2F%2Fftp.intel.com%2FPub%2Ffpgaup%2Fpub%2FIntel_Material%2F18.1%2FComputer_Systems%2FDE10-Nano%2FDE10-Nano_Computer_NiosII.pdf&usg=AOvVaw1-HoCsnC7Vin21PNHOAsmE
I/O Peripheral | Qsys Core
    On-chip memory
    character buffer Character Buffer for Video Display
    SD Card SD Card Interface
    Red LED parallel port Parallel Port
    Expansion parallel ports Parallel Port
    Slider switch parallel port Parallel Port
    Pushbutton parallel port Parallel
    Port JTAG port JTAG UART
    Interval timer Interval timer
    System ID System ID
    Peripheral Audio port Audio
    Video port Pixel Buffer DMA Controller
Test1: Open FPGA Monitor Program 18.1 - create new project - select
video example - sof is downloaded on FPGA - compile & load video.c
Result: works HDMI shows test-string
Test2: download .sof to FPGA - Eclipse for Nios - new project simple
hello world with bsp -work with .sof-put video.c and address_map_nios2.h
into project- use video.c as main, Result: works HDMI shows test-string
Test 3: do the same as Test2 , Result: random pixels in the first ~20
lines
Test 4: reinstall FPGA Monitor Program 18.1 do the same as Test2 Result:
Test 5: do the same like Test2, doesnt work, do the same like Test4
Result: random pixels in the first ~20 lines
Test 6: copy .elf from my FPGA Monitor Program 18.1 software directory
into project folder, run this this elf Result: works HDMI shows
test-string
Test 7: change something of the video.c of Test 6, Result: works HDMI
shows test-string but without the blue box !
Test 8: do the same like Test2 Result: random pixels in the first ~20
lines
Test 9: Check run configurations : select all combinations of processor
and byte stream devices Result: random pixels in the first ~20 lines
Test 10: Switch to FPGA Monitor Program 18.1, compile & Load video.c
Check: Description in
https://home.isr.uc.pt/~jfilipe/files/Final_Project_Simplified_Tutorial.pdf
( they do nearly the same...)
Check: Book EMBEDDED SoPC DESIGN WITH NIOS II PROCESSOR AND VERILOG
EXAMPLES : They say: BSP Editor will get the sopcinfo file and support
you with your access to the Hardware. Without configuring much
Check: Intel BSP documents : hey say: BSP Editor will get the sopcinfo
file and support you with your access to the Hardware. Without
configuring much
Check: Intel The Nios® II Processor: Hardware Abstraction Layer in
youtube: https://www.youtube.com/watch?v=HF7Low_sUig
I suppose that something is wrong eather with my selected sopcinfo or
with the BSP. Maybe you can give me some advice, tell me if you need
more information ! :) Thank you :D
Here are some screenshots of my development environment:
https://de.scribd.com/document/452954331/Altera-Nios-II-BSP-Summary
https://de.scribd.com/document/452954367/Question-1
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
