TWI (i2c) on Atmel atiny204/404/804
Guest #6173798
Hello,
has somebody successfully used the twi (hardware) on one of the
(relatively new) tiny-x04 chips?
I'm stuck already while trying to issue a start-condition/transmit slave
address:
After the suggested initialisation (datasheet) i'm writing TWI0.MADDR
(slave-mode) and then waiting for the WIF flag in TWI0.MSTATUS to get
set, but it never gets set. I didn't hook it up to an oszi to check
wether it starts to write the address anyways, but i suspect it doesn't.
I also took a look into the datasheets of related Devices (414, 817...)
and went through an (quite overengineered) example on start.atmel.com -
but didn't find any obvious difference in the end.
So maybe i'll revert to bit-banging but i'm just curious: Did someone
succeed with the hardware-twi on one of those chips?
Cheers,
Achim
Guest
Sorry, i accidentally wrote
>> i'm writing TWI0.MADDR (slave-mode)
but of course i'm using master-mode!
Achim
Guest
Solved it!
My misconception was that the WIF-flag in TWI0.MSTATUS would get always
set after a write to TWI0.MADDR to indicate that the transmission of the
address was finished (the datasheet is a bit fuzzy about that)
Instead it depends on wether you do a write or a read access (bit 0 of
address either 1 or 0). If you do a read access the WIF-flag will not
get set after transmitting the address, the master just proceeds with
reading one byte from the slave an then sets the RIF-flag. So you have
to check that flag (instead of WIF) when doing a read-access (of course
the same applies when you're using irq's instead of simply polling the
flags)
Here's the link that helped me to get on track:
https://www.avrfreaks.net/comment/2568566#comment-2568566
Achim
Start a new thread
