The port [clk_ch1_p_i] doesn't exist in the design
Guest #6138502
I am working on verilog project in lattice diamond. I synthesize and
compile correctly my code. I write my lpf (constraints file) to place
pins,but when i try to visualize the pin/port assignment in the
spreadsheet view ,i get these errors:
ERROR - The port [clk_ch1_p_i] doesn't exist in the design. ERROR - The
port [d0_ch1_p_i] doesn't exist in the design. ERROR - The port
[d1_ch1_p_i] doesn't exist in the design.
However these signals exist in my design and are declared in the top
module. please could someone help me.
Guest #6138546
Probably these ports are never used or in case they are used, the
signals that these ports have impact on are never assigned to output
pins. Then the systhesis throws them away. Have a look in your synthesis
report to find out.
Guest #6140125
Are there more errors of this kind or just on these signals?
Is this the toplevel of your design? If not, check whether you
accidentally tied reset_n_i constantly active somewhere outside the
module. This would remove some clocked logic from your design and thus
make clock signal obsolete.
Is the component configured to use single ended clock instead of
differential one?
And why are all ports declared as inout?
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
