FSM problems
Guest #6023190
HI,
during the development of FSM sometimes I forget to declare the status
of variable (i.e. std_logic). Just as example:
- state n: a<='1'; b<='0';
- state m: a<='0';
in the state m "b" is not declared and then it could assume any value.
Is there a way to chose the default value for a signal, in this way if I
forget to set it in a state the value will be assumed as specified
default?
thank you
maurizio stefani
Guest #6023261
You probably describe the state machine inside a clocked process. Then
an unassigned signal just keeps its value. If you go to state m from
state n, b will still be '0'.
If you want to define a default value, assign the value at the beginning
of the process. In a process only the last assigned value is assigned to
a signal.
process(clk) begin
  wait until rising_edge(clk);
  a<='0';
  b<='1';
  case state is
    when n =>
      a<='1';
      b<='0';
    when m =>
      a<='1';
  end case;
end process;
When state is n, b will be '0', when state is m, b will be '1', because
'1' is assigned to b and it is not overwritten later.
Just for clarification:
process begin
  a<='1';
  a<='0';
  a<='1';
  a<='0';
end process;
'a' will always be '0'. It will not toggle. Only the last assignment
is executed.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
