Can size of a port be input as a parameter?
OP #5991541
I have a hardware algorithm that compares two operands, each (keyBits)
bits long, and returns a logical one if the first operand is less than
the second, and returns a logical zero otherwise. This algorithm works
for any integer value of (keyBits) greater than one. So can I write my
algorithm with the following Verilog code, by passing (keyBits) in as a
parameter? I haven't tried compiling or simulating this code; quite
frankly I don't know how to do either. Can anyone help me with that?
module lessThan ( lfLessThanRg, left, right);
parameter integer keyBits = 2;
integer maxBit = keyBits - 1;
output lfLessThanRg;
input [maxBit:0] left, right;
wire[maxBit:0] notLeft;
wire[maxBit:1] ltHere, ltEve, ltBelow, equal;
or( lfLessThanRg, ltHere[ maxBit], ltEve[ maxBit]);
genvar integer bit;
generate
  for (bit = maxBit; 0 < bit; bit = bit - 1)
  begin
    and( ltHere[ bit], notLeft[ bit], right[ bit]);
    and( ltEve[ bit], equal[ bit], ltBelow[ bit]);
    or( equal[ bit], notLeft[ bit], right[ bit]);
    not( notLeft[ bit], left[ bit]);
    if (1 < bit)
    begin
      or( ltBelow[ bit], ltHere[ bit - 1], ltEve[ bit - 1]);
    end
  end
endgenerate
30
and( ltBelow[ 1], notLeft[ 0], right[ 0]);
31
not( notLeft[ 0], left[ 0]);
32
33
endmodule
Guest
Why can you not just write it like that:
parameter keyBits = 2;
input [keyBits-1:0] left, right;
assign lfLessThanRg = left < right;
endmodule
How you compile or simulate depends alot on the tools you use. I would
try  icarus verilog. I'm pretty sure you can find several tutorials in
the web for it.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
