Wordclock stopped working
OP #5967439
Hi everybody! My name is Sasha and this is my first post here.
As I understand this forum is English version of Mikrocontroller.net so
it is very strange search found nothing about Wordclock project.
I have built myself this amazing clock based on PCB from Shapelabs:
https://shapelabs.de/mechanisches/wordclock.htm
It was working fine few days than it freezes 2 times and finally stopped
working. It is completely blank now or it have just 4 (minutes LEDs) on.
LED test shows LEDs are fine. DFPlayer plays the sound manually. IR
remote does not work.
Hooking it up on serial monitor it shows all parts are online but from
web interface RTC, EEPROM and DFPlayer are offline!
LDR shows no values, DS1820 shows no temperature, time does not update,
there are no Animations, it forgets change in settings I make after
powering off. I have tried to update firmware and reset EEPROM, but no
change.
Welcome to WordClock Logger!
irmp_init...
power_init...
power_init() called
power_on...
switching power on
delay_init...
board_led_init...
button_init...
timer2_init...
wpsbutton_init...
Version: 2.9.5
Hardware: STM32F103
Display: WC12h
LEDs: WS2812 GRB
rtc is online
eeprom is online
ws2812: external pullup detected
eeprom is online
current eeprom version: 0x00000000
updating EEPROM to version 0x00020900... done
DFPLAYER LOGGER
ESP8266 LOGGER
read rtc: Su 2000-01-01 00:00:13
DFPlayer: SD card online
DFPlayer: query software version
DFPlayer: Version 0008
30
DFPlayer: set source device: 2
31
DFPlayer: set eq 0
32
DFPlayer: set volume 0
33
DFPlayer is up
34
dfplayer is online
35
esp8266 now up
36
(- setup UDP)
37
(- local port: 2421)
38
(- setup server UDP)
39
(- local port: 2424)
40
(FIRMWARE 2.9.5)
41
(- tables found; wc12h-tables-en2.txt)
42
(- check tables successful)
43
--> tabinfo<0d><0a>
44
(- connected to AP)
45
(AP crvenkapa)
46
(MODE client)
47
(IPADDRESS 192.168.1.104)
48
info: ip address = 192.168.1.104
Guest #5967633
Measure the Voltage on SDA and SCL lines, which should be 3,3V in idle
state.
If not, then remove one I²C chip after the other and powercycle the
device until the voltage is Ok.
If you removed everything but the voltage is still not 3,3V then a
pull-up resistor is possibly not working or you have a short-circuit to
GND.
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
