updating FPGA firmware in the field
Guest #5950951
hi there,
I need a solution with fpga for a specific regulation purpose which may
need to be updated with new firmware features. I am aware that xilinx
zynq platforms provide this feature but the complexity seems high (and
costs too). Is anyone aware of a PnPish solution to upgrade firmware in
the field without programming adapters? For example I want to access a
unit over a bus (Profibus or RS485) and perform a firmware upgrade using
NI labview (I am aware of the security issues). Any ideas?
Guest
Usually you would provide an interface to the flash PROM from your FPGA
and handle the programming of the flash with a simple interface to the
FPGA:
- erase flash command
- write byte/block command
- optional: read byte/block command for verify
So you just send the erase and then program the bytes(if slow is no
problem) or blocks with sequential writes, when the last write is done.
If you already have a RS485 connection from a PC to your FPGA this is
not too difficult.
Just make sure, when designing the PCB, that you have the correct pins
connected between FPGA and flash.
Some interfaces are bidrectional: you can use the pins for configuration
of the FPGA and later on read/write the flash from the FPGA. But that
differs from one FPGA/Flash to another.
Guest
Check for the XTP059 appnote at Xilinx, this also works for Kintex.
However I am only aware of Ethernet based solution, not RS485
Guest
I've got a solution implemented on the Xilinx Spartan6 using the ICAP
primitive, however it's Ethernet based. It simply acts as a bootloader
('golden' image) which will look for a valid image in the 'alternate
bootstrap' flash area. That image can be written over Ethernet, likewise
it would work on any other interface, it's just a matter of the
protocol.
I've got some basic LabVIEW support going, but haven't tested in system
upgrade in particular.
I'd strongly recommend a setup which features a CPU core. And: it's easy
to lock yourself out.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
