Evaluate two signals -- Change input Timer 1 Source between T1 and T0
OP #5886947
Hi everyone,
I'm using this code to evaluate capacity (change of frequency) on a
Bluno beetle ATmega328P.
http://interface.khm.de/index.php/lab/interfaces-advanced/arduino-frequency-counter-library/
The code works fine but I need to evaluate two signals.
Is it possible to change the input Pin T1 of timer/counter 1 to T0 or
one of the INT0/INT1?
I need to use Timer 1 because this one uses 16 bit registers. Had a look
into the .ccp-File and read the chips datasheet and went pretty deep but
could not figure out if there is a way to change the import pins. From
what I understand the T0/T1 is fixed to the timers. But I'm not an
expert so might be wrong.
I can also use an external analog switch but this is last option due to
space limitatioins.
I hope someone can help me with this
Greetings Flo
Guest #5886963
Yes, the T0 resp. T1 Pins are fixed to their timers. You cannot clock
the T0 pin to advance Timer 1.
Its is possible though, to switch the T1 Pin to output and still let
Timer 1 count pulses with it. Toggling the T1 pin by software then
clocks Timer 1.
OP #5888138
@ matzetronics
Thanks for the reply! Ok this sounds good.
I can set PD5 (T1) to output by:
DDRD =DDRD | B00000000;
But how can I then toggle for example interrupt INT1 (PD3) as input for
timer I clock edge detector?
I cann not find the register for it in the datasheet.
Can you give me a hint how to do this?
Greetings
Flo
Start a new thread
