PIC16F84 + minipro/linux (+ gpasm)
Guest #5840458
Hey all.
I Have a Minipro TL866II+ and would like to program a PIC16F84 with
using linux. The only software I found that seems to work with this
combination is https://gitlab.com/DavidGriffith/minipro . I've checked
that the hardware and software is working together, by writing binary
data to a 24C32:
$ dd if=/dev/urandom of=foo.bin count=8 bs=512 && ./minipro -p 24C32 -w foo.bin && ./minipro -p 24C32 -r bar.bin && diff bar.bin foo.bin && echo $?
8+0 records in
8+0 records out
4096 bytes (4.1 kB, 4.0 KiB) copied, 0.000526638 s, 7.8 MB/s
Found TL866II+ 04.2.103 (0x267)
Warning: Firmware is newer than expected.
  Expected  04.2.99 (0x263)
  Found     04.2.103 (0x267)
Erasing... 0.05Sec OK
Writing Code...  1.99Sec  OK
Reading Code...  0.61Sec  OK
Verification OK
0
Then I tried to read from a chip already programmed (and verified
working) with MPLABX;
minipro -p PIC16F84 -r out.bin
But: code was all zeros, config was all zeros and when specifying
retrieve data it just fails on "async data transfer."
Browsing for clues, I found one place hinting that this chip needs to be
programmed with ICSP. There's an ICSP connector on the programmer, but
I'm not sure how this is supposed to work. With MPLABX I've used a
PicKit3, and I tried to connect the board the PicKit ICSP plugs into and
run with the ICSP option, but it doesn't make a difference.
minipro -p PIC16F84 -i -r out.bin
When writing to the PIC16F84, the progress indicator tells it's writing,
but ultimately fails saying "Verification failed at address 0x0000:
File=0x83, Device=0x00"
Any hints would be welcome, either on how to make this setup work, or
alternative setups that could work that are not the proprietary PIC
stuff.
Thanks.
Start a new thread
