fpga soartan 6 io pins are no longer working
Guest #5829104
HELLO there,
i have spartan 6 of the familyxlc9  but i am facing a severe problem
with it . first i can burn successfully with jtag on it .its power is
okay but the problem is whatever code i am burning to it
the io ports values doesn't change always all the pins are zeros except
4 pins that have values between 0.9 and 1.2 and another pin that have
3.3 .although the code is working on xillinx it is a simple code. trying
to output ones on all the pins i changed the code to a code that does
nothing like the fpga sends the same values on the output pins . i
thought that those pins are no longer working
changed to another pins but all are zeros . it is like the output ports
keeps a certain previous state and stand still.
i don't know does my fpga fails and has to be changed ? although jtag is
burning code successfully
does spi flash memory is not working ? although i tried to upload the
code on fpga directly and get the same output
thanks in advance
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
