Problem with Writing a SDRAM Controller
Guest #5818180
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.NUMERIC_STD.ALL;
entity Writing is
Port(
      --SDRAM
      signal sclk  :  in  std_logic;
      signal A    :  out  std_logic_vector(12 downto 0);
      signal BA  :  out  std_logic_vector(1  downto 0);
      signal CS  :  out  std_logic:='0';
      signal RAS  :  out  std_logic:='1';
      signal CAS  :  out  std_logic:='1';
      signal WE  :  out  std_logic:='1';
      signal CKE  :  out  std_logic:='1';
      signal DQ  :  out  std_logic_vector(15 downto 0);
      signal LDQM  :  out  std_logic:='0';
      signal UDQM  :  out  std_logic:='0';
      --Control Signals
      Signal command_write  :  in     std_logic;
      Signal busy_write    :  out   std_logic:='0';
      signal row_write    :  in      std_logic_vector(12 downto 0);
      signal clmn_write    :  in      std_logic_vector(8  downto 0);
      signal Bank_write    :  in     std_logic_vector(1  downto 0);
      --Data Signal
      signal Data_write    :  in   std_logic_vector(15 downto 0)
end Writing;
30
31
architecture Behavioral of Writing is
32
33
Signal   Write_lvl   :integer:=0;      --Write Level(Steps)
34
Signal   busy_flag  :std_logic:='0';
35
36
constant Final_W_lvl:integer:=8;      --<<--<<  Final Write Level
37
38
begin
39
40
--busy_write<='1' when busy_flag='1' else
41
--         '0';
42
busy_write<= busy_flag;
43
44
Process
45
  begin
46
    wait until sclk='1';
47
    if command_write='1' then
48
      Busy_flag<=  '1';
49
    elsif write_lvl>=1 and write_lvl<=Final_W_lvl then
50
      Busy_flag<=  '1';
51
    else
52
      Busy_flag<=  '0';
53
    end if;
54
  end Process;
55
56
--Write
57
Process
58
  begin
59
60
      if Busy_flag='1' then
61
          if write_lvl<=Final_W_lvl then
62
            case write_lvl is
63
              when 0 =>
64
                --Activate                                      --Need 3 Clock (with Present Clock)--CKE Should Be High on Previous Clock
65
                CKE <= '1';                                      --This command of CKE is for Next Clock.
66
                CS   <= '0';                                      --t_RCD Needs for Activating Bank and Row.
67
                RAS <= '0';
68
                CAS <= '1';
69
                WE   <= '1';
70
                A   <= row_write;    --ROW ADDRESS
71
                BA   <= BAnk_write;      --BANK ADDRESS
72
73
              when 2 Downto 1 =>
74
                --Waiting
75
                CKE<='1';
76
                --NOP Command
77
                CS    <='0';
78
                RAS  <='1';
79
                CAS  <='1';
80
                WE    <='1';
81
82
              when 3 =>
83
                --Writing with Autoprecharge
84
                --Writing One Byte Concurrent with Write Command in this Cycle.
85
                CKE<= '1';
86
                LDQM<='0';
87
                UDQM<='0';
88
                CS <= '0';
89
                RAS<= '1';
90
                CAS<= '0';
91
                WE <= '0';
92
                A(8 Downto 0)<= clmn_write;  --COLUMN ADDRESS
93
                A(10)<= '1';            --AUTOPRECHARGE ENABLING
94
95
                DQ <= Data_write;
96
97
              when 4 =>
98
                --waiting to insure t_DPL (Data-In to Precharge Command Latency)
99
                CKE<='1';
100
                --NOP Command
101
                CS    <='0';
102
                RAS  <='1';
103
                CAS  <='1';
104
                WE    <='1';
105
106
              when 7 Downto 5 =>
107
                --Waiting for Precharge of AutoPrecharge
108
                CKE<='1';
109
                --NOP Command
110
                CS    <='0';
111
                RAS  <='1';
112
                CAS  <='1';
113
                WE    <='1';
114
115
              when others =>
116
                CKE<='1';
117
                --NOP Command
118
                CS    <='0';
119
                RAS  <='1';
120
                CAS  <='1';
121
                WE    <='1';
122
            end case;
123
            write_lvl<=write_lvl +1;
124
          end if;
125
      else
126
          write_lvl<=0;
127
      end if;
128
  end Process;
129
130
end Behavioral;
Moderator (Company: Titel) #5818217
I can see no problem.
So, tell us: what do you expect and what do you get instead? And how do
you see that wrong behaviour?
BTW: pls use the [vhdl] tags to wrap your code!
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
