BITSLIP FUNCTION STATEMACHINE
Guest #5793205
I am trying to design state machine for bitslip function. But the
simulation doesn't work correctly. Can any one please have a look and
check where is the bug? I have tried a lot but cannot find where the bug
is because according to my simulation, signal bitslip done should go
down at the input data 17c?
please see the verilog code in attachement.
Guest
// ISERDESE2: Input SERial/DESerializer with Bitslip
   //            Virtex-7
   // Xilinx HDL Language Template, version 14.6
   ISERDESE2 #(
      .DATA_RATE("DDR"),           // DDR, SDR
      .DATA_WIDTH(4),              // Parallel data width (2-8,10,14)
      .DYN_CLKDIV_INV_EN("FALSE"), // Enable DYNCLKDIVINVSEL inversion
(FALSE, TRUE)
      .DYN_CLK_INV_EN("FALSE"),    // Enable DYNCLKINVSEL inversion
(FALSE, TRUE)
      // INIT_Q1 - INIT_Q4: Initial value on the Q outputs (0/1)
      .INIT_Q1(1'b0),
      .INIT_Q2(1'b0),
      .INIT_Q3(1'b0),
      .INIT_Q4(1'b0),
      .INTERFACE_TYPE("MEMORY"),   // MEMORY, MEMORY_DDR3, MEMORY_QDR,
NETWORKING, OVERSAMPLE
      .IOBDELAY("NONE"),           // NONE, BOTH, IBUF, IFD
      .NUM_CE(2),                  // Number of clock enables (1,2)
      .OFB_USED("FALSE"),          // Select OFB path (FALSE, TRUE)
      .SERDES_MODE("MASTER"),      // MASTER, SLAVE
      // SRVAL_Q1 - SRVAL_Q4: Q output values when SR is used (0/1)
      .SRVAL_Q1(1'b0),
      .SRVAL_Q2(1'b0),
      .SRVAL_Q3(1'b0),
      .SRVAL_Q4(1'b0)
   ISERDESE2_inst (
      .O(O),                       // 1-bit output: Combinatorial output
      // Q1 - Q8: 1-bit (each) output: Registered data outputs
      .Q1(Q1),
      .Q2(Q2),
      .Q3(Q3),
      .Q4(Q4),
      .Q5(Q5),
      .Q6(Q6),
      .Q7(Q7),
      .Q8(Q8),
      // SHIFTOUT1, SHIFTOUT2: 1-bit (each) output: Data width expansion
output ports
      .SHIFTOUT1(SHIFTOUT1),
      .SHIFTOUT2(SHIFTOUT2),
      .BITSLIP(BITSLIP),           // 1-bit input: The BITSLIP pin
performs a Bitslip operation synchronous to
                                   // CLKDIV when asserted (active
High). Subsequently, the data seen on the Q1
                                   // to Q8 output ports will shift, as
in a barrel-shifter operation, one
                                   // position every time Bitslip is
invoked (DDR operation is different from
                                   // SDR).
      // CE1, CE2: 1-bit (each) input: Data register clock enable inputs
      .CE1(CE1),
      .CE2(CE2),
      .CLKDIVP(CLKDIVP),           // 1-bit input: TBD
      // Clocks: 1-bit (each) input: ISERDESE2 clock input ports
      .CLK(CLK),                   // 1-bit input: High-speed clock
      .CLKB(CLKB),                 // 1-bit input: High-speed secondary
clock
      .CLKDIV(CLKDIV),             // 1-bit input: Divided clock
      .OCLK(OCLK),                 // 1-bit input: High speed output
clock used when INTERFACE_TYPE="MEMORY"
      // Dynamic Clock Inversions: 1-bit (each) input: Dynamic clock
inversion pins to switch clock polarity
      .DYNCLKDIVSEL(DYNCLKDIVSEL), // 1-bit input: Dynamic CLKDIV
inversion
      .DYNCLKSEL(DYNCLKSEL),       // 1-bit input: Dynamic CLK/CLKB
inversion
      // Input Data: 1-bit (each) input: ISERDESE2 data input ports
      .D(D),                       // 1-bit input: Data input
      .DDLY(DDLY),                 // 1-bit input: Serial data from
IDELAYE2
      .OFB(OFB),                   // 1-bit input: Data feedback from
OSERDESE2
      .OCLKB(OCLKB),               // 1-bit input: High speed negative
edge output clock
      .RST(RST),                   // 1-bit input: Active high
asynchronous reset
      // SHIFTIN1, SHIFTIN2: 1-bit (each) input: Data width expansion
input ports
      .SHIFTIN1(SHIFTIN1),
      .SHIFTIN2(SHIFTIN2)
   // End of ISERDESE2_inst instantiation
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
