Hello there,
I have downloaded this PCA955 vhdl code from Frank Buss it work
according to the datasheet. I am trying to modify the " Read from
Register " so that it can match the receiving signal.
The Read from Register step goes:
I2C Start
Write Address(W)
Command Byte
I2C(repeated) Start condition
Write address(R)
Read Data
I2C Stop
The Read from Register step in my case goes:
I2C Start
Write Address(W)
Command Byte
I2C Stop -- This is the step I would like to add
Write address(R)
Read Data
I2C Stop
So far I have tried but the output signal is the inverse of the expected
one
I have attached the two file and I hope someone can help me
Regards,
Hello again, I don't know if it will help but it's just for a Simulation purpose. I am also thinking About modifying the slave code but it seems a bit difficult. Any help? Thanks
Hello again, well it turns out my outpout signal was the right one due to some internal port mapping in the Code. Thanks
