Trouble with downloading a code to MCU STC12C5A60S2
OP #5755248
So I bought the DIY kit from AliExpress. (All of the info links about
the thing will be at the end)
Soldered it (except the LEDs, I want to get the MCU issue resolved
first). And additionally soldered a reset button in.
It seems that at the moment my MCU (STC12C5A60S2) contains wrong code.
I tried to download the Cube code into it via 4pin UART, but the STC-ISP
just stuck at "Checking target MCU..."
I checked MCU with oscillograph and it seems to be working fine
including reset button. It recieves signals on the TxD leg, but does not
react to them.
Anything that I found so far was that my UART may be 4.25V and changing
the UART programmer will help, but:
I thought if I connect the board to a power bank and UART at the same
time then any signal from PC should be solid 5V. Correct me if I am
wrong on that.
Any help would be appreciated.
Links and info:
Everything LED Cube related (schematic, datasheets, tools, code etc.):
https://github.com/tomazas/ledcube8x8x8
AliExpress link:
https://s.click.aliexpress.com/e/LlrCw18
Start a new thread
