Neural Network on Xilinx Virtex 5
OP #5745198
Hello, I am trying to build a Neural Network on Xilinx  Virtex 5, that I
will feed it with images from this camera: OV7670 and train it in order
to determine if the person in the camera is man or woman. Is there any
VHDL core capable of implementing this processing? Ideally I would try
to achieve real-time (delay = 1-2 sec) to decide if the picture shows
man or woman. The camera I have bought is the OV7670, which takes
640x480 pictures. Can it work or I need a megapixel camera? I have,
also, found a High Definition 14 MegaPixel USB camera from ebay, and I
want to interface it with Virtex 5. Is something feasible? Where to
start from?  In the same FPGA I have to put, also, the core of the
neural network and the core of the serial interface, which will output
man or woman. I am thinking of CNN.
Thank you...
Guest #5746430
This is way too vague. What kind of research have you done on that topic
on your own?
Have you worked with neural networks before?
Do the persons cover the whole frame? Will you classify based on full
height, upper body, just face?
It is certainly possible, but you can't rely on the forum implementing
every step.
OP #5746455
I know the theory behind Neural Networks.
Worked in python, not in VHDL. Imagine only a face in front of a camera
(no has, eyeglasses) good lighting, no men dressed like woman, no woman
dressed like man. Can you help?
I have read papers about implementing CNN on VHDL, but what happens with
the RAM? I see problems there...
#5746508
do you have a running neural network code on your PC? If not I suggest
you start there because it needs to be trained and the training itself
ist most likely not going to happen on your xilinx.
Guest #5746731
A. S. is right. Training a Neural Network is the hard part that takes a
lot of computational power.
Once you have the trained network (that is a set of weights for the
non-linear nodes), the actual implementation is relatively light-weight.
Guest #5746754
Reeading your questions I suggest you start small and start reading
about neural networks and train some yourself on your computer. After
you've covered the basics, you may be able to form a clearer mental
picture of what you need to do to implement neural networks on an FPGA.
For starters, read the chapter about neural networks in Bishop's
"Machine learning and pattern recognition" (you may be able to find the
pdf online) and do Google's Machine Learning Crash Course.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
