Using WS2812B with a dsPIC30f4013 µC
OP #5731053
Hi there,
I'm doing a project which uses WS2812b addressable LEDs, but I cannot
figure out how to use them. I want to try with only one LED at first
then the idea is to use 16 LEDs to make a 4*4 matrix.
Obviously, I already tried to look at the component documentation,
doesn't help (I only got the colour control part from it with the 24bit
data).
I also tried to look for already existing projects. But what I found
mostly uses Arudinos with library's I don't have/find or understand. (I
could try to copy/paste stuff and try to change to change it until it
somehow works, but the idea is to understand it).
Could you please explain to me how it works? How to send the RGB (GRB in
the case of the WS2812b) values for one and multiple LEDs?
Thank you,
P.S.: If you have any datasheet other than the one made by
"www.world-semi.com" I would appreciate.
Start a new thread
