VHDL output signal in hexadecimal instead of binary
Guest #5698701
Hello.
I am trying to simulate a vhdl Code using a text files. the Output
Signal is correct except that it's in binary. I would like to know what
command line I can add to have it in hexadecimal. My Code look like
this.
file_open(vectors, "input_vectors.txt", read_mode);
file_open(results, "output_results.txt", write_mode);
while not endfile(vectors) loop
   readline(vectors, iline);
   read(iline, a_in);
   write(oline, output_data); -- it's any modification needed here
end loop;
file_close(vectors);
file_close(results);
Many thanks
Guest #5699564
Hello.
@moderator thanks for the edit.
Thanks a lot for the link Duke. I have tried one of the example and it
work. I just have to Change the "write" line to
 hwrite (oline, output_data);
Once again thanks for the help
Guest #5705176
Hallo again.
I don't know if I should start a new tread or continue here. I am facing
another Problem. I would like the values I am reading from the input
text file to appear on the waveform window of the Simulation Software
(Active-HDL). These Signals only appear as Zero (0) in the waveform. My
Code look like:
 Signal e_in            : std_logic;
       Signal a_in            : std_logic_vector(31 downto 0);
       Signal b_in            : std_logic_vector(3 downto 0);
      process
          variable s         : string(1 to 300);
          variable iline     : line;
          variable oline     : line;
          variable e_in      : std_logic;
          variable a_in      : std_logic_vector (31 downto 0);
          variable sapce     : character;
             if (s(1 to 3)= "#AE") then
             read(iline, space);
             hread(iline, a_in);  --This value to appear on the waveform
             read (iline, space);
             read (iline, e_in);  -- as well as this value
             read (iline, b_in);  -- and this one too
             in_a <= a_in;
             in_e <= e_in;
             in_b <= b_in;
           elsif
30
31
             hwrite(oline, output_data);
32
             end loop;
33
34
35
the Content of my Input file
#AE 0000001A 1 0010
      #CDE 00FC0011 0001 00000274
Many thanks
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
