Control of home temperature etc
OP #5672131
Hello dear Communty,
This seems to be the greatest competence in electronics that I could
find, so I have a lot of questions, I start with a few, think too much
at once is not good?
So:
I would like to reach a constant room temperature because of an
autonomous dysfunction, disorder of the autonomic nervous system,
unfortunately, the normal heating is unsuitable.
The first question, which temperature gauges do I need here? Best a
quartz vibration sensor, or what these are called, right?
With this I could control heating elements by means of a control unit,
eg PC with interface.
In addition, I would need a control of humidity, I believe rich here any
normal sensor? The air just should not be too dry.
The question then would be nnur how I humidify the air, I have not found
a suitable answer, you would need a controllable humidifier. Or do you
have an idea?
Furthermore, there would still be a question, if I have CO2, and pCO2
sensors, etc, can then be rebuilt something like that s.PC?
https://www.ebay.com/itm/CO2-Patient-Monitor-ICU-Vital-Signs-Monitor-Printer-ECG-NIBP-SPO2-RESP-TEMP-PR/112978931473?hash=item1a4e11af11:rk:1:
pf: 0
Would probably cheaper to buy the same device?
Actually, I only need the CO2 module and that's also needed, and stop
o2.
So hope that was not too much now.
Kind regards
Guest #5673684
Huch, that's difficult to understand, but I'll try to give my best.
Why are you trying to build a device to control the air quality by
yourself?
I think it would be much easier to just buy a single device.
First: Do you have any experiences about programming and electronics?
That would be needed or deeply recommended.
The parts you need are depending on the room(s) you have.
I think there must be any device somewhere on the market wich are fine
for you.
Hope I could have helped you
Start a new thread
