Datapath 8 bits VHDL Modelsim
Guest #5589387
• ▲ useful
▼ not useful
Bonjour,
Depuis plusieurs jours j’essaye de savoir pourquoi la simulation
modelsim m’affiche pour output :UUUUU
Si quelqu’un peut m'aider a comprendre
Voici la capture d'écran de modelsim : https://prnt.sc/l6dtin
Voici les codes pour les différents composants:
-- datapath .vhd
library ieee ;
use ieee.std_logic_1164.all ;
use work.pack.all;
entity datapath is port( clk: in std_logic;
                 input: in std_logic_vector(7 downto 0);
                 ie: in std_logic;
                 we: in std_logic;
                 wa: in std_logic_vector(1 downto 0);
                 rae: in std_logic;
                 raa: in std_logic_vector(1 downto 0);
                 rbe: in std_logic;
                 rba: in std_logic_vector(1 downto 0);
                 opcode: in std_logic_vector(2 downto 0);
                 shsel: in std_logic_vector(1 downto 0);
                 oe: in std_logic;
                 output: out std_logic_vector(7 downto 0));
end datapath ;
architecture behavior of datapath is
signal muxout, rfAout, rfBout: std_logic_vector(7 downto 0);
signal aluout, shiftout, tristateout: std_logic_vector(7 downto 0);
begin
U0: mux2 port map( ie, input, shiftout, muxout );
U1: regfile port map(clk,we,wa,muxout,rae,raa,rbe,rba,rfAout,rfBout );
U2: alu port map( opcode, rfAout, rfBout, aluout );
30
U3: shifter port map(shsel,aluout,shiftout);
31
U4: tristatebuffer port map(oe, shiftout, tristateout);
32
output <= tristateout;
33
end behavior;
34
35
-- mux2 .vhd
36
37
library ieee ;
38
39
40
entity mux2 is port( s: in std_logic;                   -- select line
41
              d1, d0: in std_logic_vector(7 downto 0);   -- data bus input
42
              y: out std_logic_vector(7 downto 0));     -- data bus output
43
end mux2;
44
architecture behavior of mux2 is
45
  begin
46
    process(s, d1, d0)
47
      begin
48
        if(s = '0')then
49
          y <= d0;
50
        else
51
          y <= d1;
52
        end if;
53
    end process;
54
end behavior;
55
56
-- regfile .vhd
57
58
library ieee ;
59
60
use ieee.std_logic_unsigned.all;
61
use ieee.numeric_std.all;
62
63
entity regfile is port( clk: in std_logic;                     --clock
64
                we: in std_logic;                     --write enable WE
65
                wa: in std_logic_vector(1 downto 0);         --write address WA
66
                input: in std_logic_vector(7 downto 0);       --input
67
                rae: in std_logic;                     --read enable port A
68
                raa: in std_logic_vector(1 downto 0);         --read address port A
69
                rbe: in std_logic;                     --read enable port B
70
                rba: in std_logic_vector(1 downto 0);         --read address port B
71
                Aout, Bout: out std_logic_vector(7 downto 0));  --output port A & B
72
end regfile;
73
architecture behavior of regfile is
74
    subtype reg is std_logic_vector(7 downto 0);
75
    type regArray is array(0 to 3) of reg;
76
    signal rf: regArray; --register file contents
77
  begin
78
    WritePort: process(clk)
79
  begin
80
    if (clk'event and clk = '1')then
81
      if (we = '1')then
82
        rf(to_integer(unsigned(wa))) <= input;
83
      end if;
84
    end if;
85
  end process;
86
    ReadPortA: process(rae, raa)
87
  begin
88
    if (rae = '1') then
89
      Aout <= rf(to_integer(unsigned(raa))); -- convert bit VECTOR to integer
90
    else
91
      Aout <= (others => '0');
92
    end if;
93
  end process;
94
    ReadPortB: process(rbe, rba)
95
  begin
96
    if (rbe = '1') then
97
      Bout <= rf(to_integer(unsigned(rba))); -- convert bit VECTOR to integer
98
    else
99
      Bout <= (others => '0');
100
    end if;
101
  end process;
102
end behavior;
103
104
-- alu .vhd
105
106
library ieee ;
107
108
109
110
entity alu is port( opcode: in std_logic_vector(2 downto 0);   -- select for operations
111
              a, b: in std_logic_vector(7 downto 0);     -- input operands
112
              f: out std_logic_vector(7 downto 0));     -- output
113
end alu;
114
architecture behavior of alu is
115
  begin
116
  PROCESS(opcode, a, b)
117
    begin
118
    case opcode is
119
    when "000" => f <= a;      -- pass
120
    when "001" => f <= a and b;  -- and
121
    when "010" => f <= a or b;    -- or
122
    when "011" => f <= not b;    -- not
123
    when "100" => f <= a + b;    -- add
124
    when "101" => f <= a - b;    -- substact
125
    when "110" => f <= a + 1;    -- increment
126
    when "111" => f <= a - 1;    -- decrement
127
    when others => f <= (others => '0');
128
    end case;
129
  end process;
130
end behavior;
131
132
-- shifter .vhd
133
134
library ieee ;
135
136
137
entity shifter is port( shsel: in std_logic_vector(1 downto 0);     -- select for operations
138
                input: in std_logic_vector(7 downto 0);     -- input operands
139
                output: out std_logic_vector(7 downto 0));   -- output
140
end shifter;
141
architecture behavior of shifter is
142
  begin
143
  process(shsel, input)
144
  begin
145
    case shsel is
146
    when "00" => output <= input;                 -- pass
147
    when "01" => output <= input(6 downto 0) & '0';     -- shift right
148
    when "10" => output <= '0' & input(7 downto 1);     -- shift left
149
    when "11" => output <= input(0) & input(7 downto 1);  -- rotate right
150
    when others => output <= (others => '0');
151
    end case;
152
  end process;
153
end behavior;
154
155
-- tristatebuffer .vhd
156
157
library ieee ;
158
159
use ieee.std_logic_arith.all;
160
161
162
entity tristatebuffer is port( e: in std_logic;               -- single buffer input
163
                     d: in std_logic_vector(7 downto 0);  -- single buffer enable
164
                     y: out std_logic_vector(7 downto 0));  -- single buffer output
165
end tristatebuffer;
166
architecture behavior of tristatebuffer is
167
  begin
168
  process (e, d) -- get error message if no d
169
  begin
170
    if (e = '1')then
171
      y <= d;
172
    else
173
      y <= (others => 'Z'); -- to get 8 Z values
174
    end if;
175
  end process;
176
end behavior;
177
178
-- datapath_tb .vhd
179
180
library ieee;
181
use ieee.std_logic_1164.all;
182
183
184
185
186
entity datapath_tb is
187
end datapath_tb;
188
189
architecture behavior of datapath_tb is
190
-- Component Declaration for the Unit Under Test (UUT)
191
component datapath port( clk: in std_logic;
192
193
                 ie: in std_logic;
194
                 we: in std_logic;
195
196
                 rae: in std_logic;
197
198
                 rbe: in std_logic;
199
200
201
202
                 oe: in std_logic;
203
204
end component;
205
  --inputs
206
  signal clk : std_logic := '0';
207
  signal input : std_logic_vector(7 downto 0) := (others => '0');
208
  signal ie : std_logic := '0';
209
  signal we : std_logic := '0';
210
  signal wa : std_logic_vector(1 downto 0) := (others => '0');
211
  signal rae : std_logic := '0';
212
  signal raa : std_logic_vector(1 downto 0) := (others => '0');
213
  signal rbe : std_logic := '0';
214
  signal rba : std_logic_vector(1 downto 0) := (others => '0');
215
  signal opcode : std_logic_vector(2 downto 0) := (others => '0');
216
  signal shsel : std_logic_vector(1 downto 0) := (others => '0');
217
  signal oe : std_logic := '0';
218
  --Outputs
219
  signal output : std_logic_vector(7 downto 0);
220
  -- Clock period definitions
221
  constant clock_period : time := 50 ns;
222
223
  begin
224
225
  -- Instantiate the Unit Under Test (UUT)
226
  uut: datapath port map(clk, input, ie, we, wa, rae, raa, rbe, rba, opcode, shsel, oe, output);
227
228
  -- Clock process definitions
229
  clock_process :process
230
  begin
231
    clk <= '0';
232
    wait for clock_period/2;
233
    clk <= '1';
234
235
  end process;
236
237
  -- Stimulus process
238
  stim_proc: process
239
  begin
240
  -- hold reset state for 100 ns.
241
  --Initialize inputs
242
243
    input <= "00000000";      -- input binary 4
244
    ie <= '0';               --input enabled
245
    wa <= "00";           -- input stored in address binary 0
246
    we <= '0';            --write enabled
247
    raa <= "00";
248
    rae <= '0';
249
    rba <= "00";
250
    rbe <= '0';
251
    opcode <= "000";
252
    shsel <= "00";
253
    oe <= '0';
254
255
    wait for 50 ns;
256
    input <= "00000100";    -- input binary 4
257
    ie <= '1';             --input enabled
258
259
    we <= '1';          --write enabled
260
    raa <= "00";
261
    rae <= '0';
262
    rba <= "00";
263
    rbe <= '0';
264
    opcode <= "000";
265
    shsel <= "00";
266
    oe <= '0';
267
268
    wait for 50 ns;
269
270
    ie <= '0';
271
    wa <= "01";      --store result of the operation done in the ALU in address binary 1 the result is 1000
272
    we <= '1';      --write in address enabled
273
    raa <= "00";      --read address 0 in A
274
    rae <= '1';      --read enabled
275
    rba <= "00";      --read address 0 in B
276
    rbe <= '1';      --read enabled
277
    opcode <= "100";  --add A + B = 100+100=1000
278
    shsel <= "00";
279
    oe  <= '1';
280
281
    -- insert stimulus here
282
283
    wait;
284
    end process;
285
286
end;
287
288
--addresses 00 = 00000100 binary 4
289
--addresses 01 = 00001000 result binary 8
290
--addresses 10
291
--addresses 11
292
293
--pack. vhd
294
295
library ieee ;
296
297
package pack is
298
component mux2 port(  s: in std_logic;                   -- select lines
299
300
301
end component;
302
component regfile port( clk: in std_logic;                     --clock
303
304
305
306
307
308
309
310
311
end component;
312
component alu port( opcode: in std_logic_vector(2 downto 0);   -- select for operations
313
314
315
end component;
316
component shifter port( shsel: in std_logic_vector(1 downto 0);     -- select for operations
317
318
319
end component;
320
component tristatebuffer port( e: in std_logic;               -- single buffer input
321
322
323
end component;
324
end pack ;
#5589430
• ▲ useful
▼ not useful
Salut
au début, je bien voudrais dire que ce n'est pas bon avec les 4
bibliothèques, ils pourraient se déranger. Aussi les nombreux paramètres
derrière le signal clock dans la liste de sensibilité peut faire des
problèmes.
Je ne suis pas sûr, quel est le problème exact mais si seulement la
simulation fait des problèmes, c'est souvent un compteur qui n'est pas
initialisé.
  • [vhdl]VHDL-Code[/vhdl]
