Hello everyone, I am a beginner in Verilog. Here's a simple code for behavioral modeling: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ module first_system(out1,out2,in1,in2); // Port definitions input in1,in2; output out1,out2; // Description of the digital system // Behavioral modeling reg out1,out2; initial begin out1 = 0; out2 = 0; end always @ (in1, in2) begin out1 = (in1 & in2) ^ (in1 | in2); out2 = ~ in2; end endmodule ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Now the textbook says that "The always keyword executes the beneath description block (encapsulated by begin and end keywords) whenever in1 or in2 changes. If there is no change in these variables, output will not be provided by the system." Here out1 and out2 are two LEDs and in1 and in2 are two switches. So my understanding is since out1 and out2 are intialized as 0s, the two LEDs should be both off until we toggle the switches. However, after I program it to a Basys3 board, the LEDs can be on in the very beginning even if I haven't done anything to the switches. So my question is: did I misunderstand anything in here? Also, is there a way to let the board not show any outputs (not turn on any LEDs) until we change the states of the switches? Thank you so much in advance!!!
