Device for complex mathematical calculations with 15 to 20 variables(inputs)
Guest #5565295
I plan to build an device that can handle up to 15 -20 inputs and use
them for calculations over 6 steps while the following calculation must
be based on the prior one + new input it is given. It also has to output
the result after every calculation. I am a total noob depending
microcontrollers so I dont know how and where to start. Would be happy
if someone who is into this stuff could offer a bit of his time so I can
explain what I want to use it for and what are the points that matter to
me and then give me a hint to the right direction where I should be
looking for the information I need to realize that.
Thanks in advance PolyToxic
Guest
What kind of inputs are these? Sensors? Or just data entered by the
user?
In the latter case, I'd go for an app on a tablet, for example.
Guest
Data entered by user. I also thought that software would be the easier
way. Just wanted to know if its possible at all
Guest
Of course it's possible. There were more than 6 calculation steps needed
to fly to the moon and that worked 49 years ago! ;)
However nowadays doing that on a microcontroler is probably indeed not
the optimal way.
If you do have a clue about math already, you could look at "Matlab".
That's a development system with integrated programming language.
It's often used by mathematicians to perform complex computations. Input
and output are no problem and there are tons of tutorials to learn.
Same counts for the free alternative "GNU octave".
If you directly want to write an application, look at a programming
language like Python and Java. Those are easy to learn.
Another way could be to use HTML and JavaScript. So the result is
directly a website (it does not necessarily need a server by the way).
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
