Counter and Alter FIFO using VHDL/Verilog
OP #5555862
   I have written simple verilog code for counter. But i dont need that.
I need to control FIFO from counter block.
Please find the attachment of counter and FIFO design.
I need to control the FIFO__in_write signal only.
I want to change the design to check whether the fifo is full or not and
only write the value (and increment the counter) when the fifo is not
full.
 I need help in Verilog coding part.
Guest #5556107
Can't help you with Verilog. But I think, you just want to compare the
value of counter with your FIFO size. Doing this in Verilog should not
be a problem for you. If it is - post your code that did not work. I am
pretty sure someone out there will find your mistake.
(Company: Maven Silicon) #5556310
You can also refer to the video https://youtu.be/uUZceAfnVNk for a great
understanding of #verilog. This tutorial covers registers, unwanted
latches & operator synthesis and helps you master these fundamental
concepts.Check out the series of free tutorials by Mr. P R
Sivakumar(CEO, Maven Silicon) on basic and advanced concepts of Front
End VLSI. His amazing explanations and easy to understand content make
these videos a great tool for you to update and upgrade your VLSI
skills.
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
