Printer-Microcontroller
Guest #5539851
Hi.
I would like to have information about thermal transfer printers or
label printers that can be used with a microcontroller. To which I can
send information from a microcontroller.
I would also like to know if I can use a common thermal printer to print
adhesive labels.
I found this
https://www.adafruit.com/product/597
but I dont know if it can be used to print thermal label roll. Like
this:
https://www.officeworks.com.au/shop/officeworks/p/zebra-direct-thermal-label-roll-100-x-150mm-1000-labels-inz1342215
Guest #5540004
Well, the adafruit printer only prints on 2.25" inch (57mm) wide thermal
rolls while your desired labels are 100mm in width.
So the answer is no, adafruit cannot print your labels, even if the
technology would be the right one (thermal transfer).
Guest #5541464
Look for Zebra printers on ebay. Many of them have serial or parallel
interfaces, and it is no problem to use a uC to send data to them. The
printer command codes are documented, and they can produce barcodes
internally.
They are not exactly cheap, though.
fchk
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
