Reverse polarity via GPIO
Guest #5460053
I have a Raspberry Pi camera with switchable IR filter, I want to
control this filter with the GPIOs of the Raspberry Pi. I used an
oscilloscope (see my images) to measure the switching signal (by default
the filter is switched by the led of camera). To make the filter switch
in one direction I need to apply 3,3V for about 150ms (no problem so
far) but to switch it back (to make the filter go away) I need to apply
the 3,3V with reversed polarity.
What (easy and cheap) circuit can I use to give a signal in both
directions?
(So one GPIO in one direction and another for the other direction.
Guest
I think you should control a half bridge with two gpios.
Generate the -3v3 with a single inverting charge pump. You don't tell
about current needs. There are many cheap charge pump ICs like icl7660
available.
Guest
Thank you very much, that looks very promising. Current draw should be
minimal as it uses a power rail thought for a SMD LED, I haven't
measured it though
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
