FPGA image fusion & stereo vision
Guest #5383734
• ▲ useful
▼ not useful
I would like to create an embedded multispectral stereovision system
using 4 sensors (4k@60 fps).
I use 2 sensors for each eye (1 rgb and 1 near-infrared (nir) sensor
with a dichroic beam splitter) in order to capture rgb & nir videos for
each eye.
I have to fusion the videos capture by the sensors for each eye (rgb and
nir videos). Then, i have to merge the two videos in order to display it
on a VR headset (HDMI output).
Is this project possible only by using a single FPGA connected to 4
sensors and a HDMI VR Headset without any CPU/GPU (Tegra) ? Which FPGA
is the most suitable according to your experience ?
Thank you.
  • [vhdl]VHDL-Code[/vhdl]
