Controlling the tasks
OP (Company: None) #5370048
• ▲ useful
▼ not useful
Hello,
I have a strange question with regards to task control in verilog test
bench, so please bear with my attempt to trying to keep it to a simple
form.
I have a task flow inside a file, for which I am not permitted to change
anything. For example;
   1) File: Faults
  task examine;
  begin
  task a();
  task b();
  end
  the explanations for task a and b are also inside the file-Fault for
which I am not permitted to make any changes.
However I am using the above task in my test case
  2) File : Testcase_1
   task xyz;
   task examine;
   task hml; etc..
however there is a problem with task a. when task-a runs, there is a
variable inside that task which is changing wrongly and I have to force
the variable to follow the right formula somewhere else and correct it
without doing the task correction in the Faults file.
I have access to  another file called as File: utility where I can write
the correct formula to force the variable to follow the new formula, get
changed and then continue executing with task b and so on in my test
case and produce the results.
But I dont know how can I stop task a in the middle and then change the
variable(force it follow a new formula and get the right value) and then
continue with task b and so on. Can anybody help me with this???
i am happy to provide additional info if required. Thanks in advance
  • [vhdl]VHDL-Code[/vhdl]
