Looking for a comparator IC with programmable threshold
Guest #5360282
• ▲ useful
▼ not useful
Hello,
I'm looking for an IC that provides the functionality of a a comparator
or schmitt trigger with a digitally programmable threshold.
Ideally the IC has a single comparator channel which allows setting the
threshold via an SPI interface. A supply voltage in the range of +-5V
and an 8 Bit resolution would be perfect.
The best I have found so far is an MAX516 "Quad comparator with
programmable threshold"
(https://www.maximintegrated.com/en/products/analog/amplifiers/MAX516.html).
The MAX 516 however has an parallel bus and does not really improve
sizewise on a solution build with separate DAC and comparater ICs.
Does anyone by any chance have a suggestion for a part, or for better
search terms?
Regards
cmppt
