Hi all is it possible to do a design in VIVADO based on self made schematics + VIVADO IPs + some VHDL code +some vhdl based testbench that will help simulation of the whole design ?
Schematic is a very ambiguous term, what do you mean with this term? The rest ist possible. As nearly everything is possible if you describe is as unprecise as possible.
Schematics is a design based on gates only like or nand , counter without any vhdl jast the testbench used to simuate that gates based design. Elico
But how will you tell your software what kind of nand and other blocks you want to use? What is your design entry method? I would say no as there is no way in Vivado to entry a design in any form of schematic (and as is doesn't make sense). And of couse you could misuse block designs, but that creates more problems and makes it harder than just transfering the schematics to a HDL of your choice. And by the way, building designs based on NANDs isnt very useful in the FPGA design area as your base building blocks differ from the blocks you would use in another IC design flow.
