Logical case equality and inequality operators utilizing No of LUTs
OP #5331140
• ▲ useful
▼ not useful
Hello
I am working on point addition algorithm for ecc implementation,the
verilog code is having logical case equality and inequality operators
utilizing 238 % LUTs.
I am targeting Nexys 4 ddr FPGA board
In verilog code,
line no 33-
wire addinf = ((x2 === zreg && y2 === zreg) && (x1 !== zreg && y1 !==
zreg)) || ((x1 === zreg && y1 === zreg) && (x2 !== zreg && y2 !==
zreg));
When these operators are replaced with logical equality and logical
inequality(!= and ==)operators then the no of luts decreases but it
affects simulation results
wire addinf = ((x2 == zreg && y2 == zreg) && (x1 != zreg && y1 != zreg))
|| ((x1 == zreg && y1 == zreg) && (x2 != zreg && y2 != zreg));
I have attached the verilog code and the screenshot of 2 project summary
Any suggestions to this problem?
Guest #5331148
• ▲ useful
▼ not useful
You are STILL using all those modulo operators. Can't you just find an
algorithm that's actually suited for implementation? There has to be
some way to do this more efficiently.
Other than that, changing the addinf line likely results in a constant
value for addinf which leads xst to synthesize away most of your code.
Not sure why though, the === and !== operators don't make any sense for
implementation anyways.
  • [vhdl]VHDL-Code[/vhdl]
