Write a very simple controller for a flash memory in a IC board
OP #5330122
• ▲ useful
▼ not useful
As a school project I want to write a very simple controller for a flash
memory in a IC board. The FPGA(Knowledge about FPGA:
http://www.apogeeweb.net/article/67.html) chip is Altera 5CEFA4F23C8 and
the flash is MX25L3206E.
I did an effort to produce the SCLK, SI and other signals that the chip
needs through verilog, respecting the timing etc. I conceived the
controller as a finite state machine that suppose to generate the SPI
signals in order.
I have loaded the system to the board but it is not receiving anything
from SO as I thought it would do automatically.
I'm using a "testbench-like" module that produce the avalon control,
address and data signals like write, read and address, for a future
implementation on a larger Avalon communication protocol SoC.
I'm adding the code I write for your reference.
    module FLASH_CTL (
 ////////////// avalon interface///////////////////
    input   wire [23:0] avalon_slave_address,
    input   wire [3:0]  avalon_slave_byteenable,
    input   wire        avalon_slave_read,          //             .read
    input   wire        avalon_slave_write,         //             .write
    input   wire [31:0] avalon_slave_writedata,     //             .writedata
    input   wire        reset_sink_reset,           //   reset_sink.reset
    input   wire        clock_sink_clk,             // clock_sink_1.clk
    output wire [31:0]  avalon_slave_readdata,      //             .readdata
    output wire avalon_slave_readdatavalid, //             .readdatavalid
    output wire avalon_slave_waitrequest,   //             .waitrequest
//////////////// chip interface ///////////////////
    input wire SO,
    output reg SI,
    output reg CS,
    output wire WP,
    output wire HOLD,
    output reg SCLK
parameter ST_0 = 4'd0; parameter ST_1 = 4'd1; parameter ST_2 = 4'd2; parameter ST_3 = 4'd3;
parameter ST_4 = 4'd4; parameter ST_5 = 4'd5; parameter ST_6 = 4'd6; parameter ST_7 = 4'd7;
parameter ST_8 = 4'd8; parameter ST_9 = 4'd9; parameter ST_10 = 4'd10; parameter ST_11 = 4'd11;
30
31
parameter wr_comm = 8'b0000_0010; // PROGRAM  0X02, write 0000_0010
32
parameter rd_comm = 8'b0000_0011; // PROGRAM  0X03, read 0000_0011
33
34
35
36
parameter test_A = 8'b0001_1111;
37
38
39
reg [7:0] test_reg;
40
41
42
always@ (posedge  clock_sink_clk or negedge reset_sink_reset) begin
43
    if (~reset_sink_reset)
44
        test_reg <= 0;
45
    else
46
        test_reg <= test_A;
47
end
48
49
50
51
52
53
reg [31:0] av_wrdata;
54
reg f_cyc_count, enable, rd_SO, f_bit_count, wr_mode, word_ak, clear_byte_c;
55
reg av_rd7, av_rd6, av_rd5, av_rd4, av_rd3, av_rd2, av_rd1, av_rd0;
56
reg [3:0] state, nextstate;
57
reg [4:0] cyc_count, byte_count;
58
reg [7:0] comm_in, data_in, av_rd_byte1, av_rd_byte2, av_rd_byte3, av_rd_byte4;
59
reg [23:0] addr_in;
60
reg [4:0] bit_count;
61
wire [7:0] av_rd_buff;
62
reg [2:0] bytes_enabled;
63
wire burstcount, debugaccess;
64
65
assign WP = 1;
66
assign HOLD = 1;
67
assign avalon_slave_waitrequest = ~ CS;
68
assign avalon_slave_readdatavalid = (CS && state >= 1 && wr_mode)? 1'b1:1'b0;
69
assign avalon_slave_readdata = {av_rd_byte1, av_rd_byte2, av_rd_byte3, av_rd_byte4};
70
assign av_rd_buff = {av_rd7, av_rd6, av_rd5, av_rd4, av_rd3, av_rd2, av_rd1, av_rd0};
71
assign burstcount = 0;
72
assign debugaccess = 0;
73
74
75
always@ (posedge  clock_sink_clk or negedge reset_sink_reset)begin
76
77
    bytes_enabled <= 1;
78
else begin
79
    bytes_enabled <= bytes_enabled;
80
    case (avalon_slave_byteenable)
81
        4'b0001:    bytes_enabled <= 3'd0;
82
        4'b0011:    bytes_enabled <= 3'd1;
83
        4'b0111:    bytes_enabled <= 3'd2;
84
        4'b1111:    bytes_enabled <= 3'd3;
85
        default:    bytes_enabled <= bytes_enabled;
86
    endcase
87
end
88
end
89
90
91
92
    state <= ST_0;
93
else
94
    state <= nextstate;
95
96
97
always@ (*) begin
98
CS <= 0; SI <= 0; SCLK <= 0; f_bit_count <= 0; f_cyc_count <= 0; rd_SO <= 0; word_ak <= 0; clear_byte_c <= 0;
99
case (state)
100
ST_0:   begin
101
            if (enable) begin
102
            nextstate <= ST_1;
103
            CS <= 0;
104
            end
105
            else begin
106
            nextstate <= ST_0;
107
            CS <= 1;
108
            end
109
        end
110
111
ST_1:   begin
112
            SI <= 0;  // dont care
113
            SCLK <= 1;
114
            if (cyc_count == 10) begin
115
                    f_cyc_count <= 0;
116
                    nextstate <= ST_2;
117
            end
118
            else begin
119
                    f_cyc_count <= 1;
120
                    nextstate <= ST_1;
121
            end
122
        end
123
124
ST_2:   begin                                       ///// send command
125
            SI <= comm_in [7 - bit_count];
126
            SCLK <= 0;
127
128
                    f_cyc_count <= 0;
129
                    nextstate <= ST_3;
130
            end
131
            else begin
132
                    f_cyc_count <= 1;
133
                    nextstate <= ST_2;
134
            end
135
        end
136
137
ST_3:   begin
138
139
            SCLK <= 1;
140
141
                f_cyc_count <= 0;
142
                f_bit_count <= 1;
143
                if (bit_count == 7) begin
144
                    nextstate <= ST_4;
145
                    word_ak <= 1;
146
                    clear_byte_c <= 1;
147
                end
148
                else begin
149
                    clear_byte_c <= 0;
150
                    nextstate = ST_2;
151
                    word_ak <= 0;
152
                end
153
            end
154
            else begin
155
                word_ak <= 0;
156
                f_bit_count <= 0;
157
                f_cyc_count <= 1;
158
                nextstate <= ST_3;
159
            end
160
        end
161
162
ST_4:   begin                                           ///// send address
163
            SI <= addr_in [23 - bit_count];
164
            SCLK <= 0;
165
            f_bit_count <= 0;
166
167
                    f_cyc_count <= 0;
168
                    nextstate <= ST_5;
169
            end
170
            else begin
171
                    f_cyc_count <= 1;
172
                    nextstate <= ST_4;
173
            end
174
        end
175
176
177
ST_5:   begin
178
179
            SCLK <= 1;
180
181
                f_cyc_count <= 0;
182
                f_bit_count <= 1;
183
                if (bit_count == 23) begin
184
                    word_ak <= 1;
185
                    clear_byte_c <= 1;
186
                    if (wr_mode)
187
                    nextstate = ST_6;
188
                    else
189
                    nextstate = ST_9;
190
                end
191
                else begin
192
                    clear_byte_c <= 0;
193
                    nextstate = ST_4;
194
                    word_ak <= 0;
195
                end
196
            end
197
            else begin
198
                    word_ak <= 0;
199
                    f_cyc_count <= 1;
200
                    nextstate <= ST_5;
201
            end
202
        end
203
204
ST_6:   begin                                   /// write
205
            SI <= data_in [7 - bit_count];
206
            SCLK <= 0;
207
            f_bit_count <= 0;
208
209
                f_cyc_count <= 0;
210
                nextstate <= ST_7;
211
            end
212
            else begin
213
                f_cyc_count <= 1;
214
                nextstate <= ST_6;
215
            end
216
        end
217
218
ST_7:   begin
219
220
            SCLK <= 1;
221
222
                f_cyc_count <= 0;
223
                f_bit_count <= 1;
224
225
                    word_ak <= 1;
226
                    if (byte_count == bytes_enabled) begin
227
                        clear_byte_c <= 1;
228
                        nextstate <= ST_8;
229
                    end
230
                    else begin
231
                        clear_byte_c <= 0;
232
                        nextstate <= ST_6;
233
                    end
234
                end
235
                else begin
236
                    clear_byte_c <= 0;
237
                    word_ak <= 0;
238
                    nextstate = ST_6;
239
                end
240
            end
241
            else begin
242
                clear_byte_c <= 0;
243
                word_ak <= 0;
244
                f_bit_count <= 0;
245
                f_cyc_count <= 1;
246
                nextstate <= ST_7;
247
            end
248
        end
249
250
ST_8:   begin
251
            rd_SO <= 0;
252
            CS <= 1;
253
254
                    f_cyc_count <= 0;
255
                    nextstate <= ST_0;
256
            end
257
            else begin
258
                    f_cyc_count <= 1;
259
                    nextstate <= ST_8;
260
            end
261
        end
262
263
264
ST_9:   begin
265
            rd_SO <= 0;                     // read
266
            SI <= 0;
267
            SCLK <= 0;
268
            f_bit_count <= 0;
269
270
                    f_cyc_count <= 0;
271
                    nextstate <= ST_10;
272
            end
273
            else begin
274
                    f_cyc_count <= 1;
275
                    nextstate <= ST_9;
276
            end
277
        end
278
279
ST_10:  begin
280
            rd_SO <= 1;
281
282
            SCLK <= 1;
283
284
                f_cyc_count <= 0;
285
                f_bit_count <= 1;
286
287
                    word_ak <= 1;
288
289
                        clear_byte_c <= 1;
290
                        nextstate <= ST_11;
291
                    end
292
                    else begin
293
                        clear_byte_c <= 0;
294
                        nextstate <= ST_9;
295
                    end
296
                end
297
                else begin
298
                    clear_byte_c <= 0;
299
                    word_ak <= 0;
300
                    nextstate = ST_9;
301
                end
302
            end
303
            else begin
304
                clear_byte_c <= 0;
305
                word_ak <= 0;
306
                f_bit_count <= 0;
307
                f_cyc_count <= 1;
308
                nextstate <= ST_10;
309
            end
310
        end
311
312
313
ST_11:  begin
314
            rd_SO <= 0;
315
            CS <= 1;
316
317
                    f_cyc_count <= 0;
318
                    nextstate <= ST_0;
319
            end
320
            else begin
321
                    f_cyc_count <= 1;
322
                    nextstate <= ST_11;
323
            end
324
        end
325
326
default: begin
327
            CS <= 0; SI <= 0; SCLK <= 0; f_bit_count <= 0; f_cyc_count <= 0; nextstate <= ST_0;
328
            rd_SO <= 0; clear_byte_c <= 0;
329
         end
330
endcase
331
end
332
333
always@(posedge  clock_sink_clk or negedge reset_sink_reset)    begin
334
    if (~reset_sink_reset) begin
335
        av_rd7 <= 0; av_rd6 <= 0; av_rd5 <= 0; av_rd4 <= 0;
336
        av_rd3 <= 0;av_rd2 <= 0;av_rd1 <= 0;av_rd0 <= 0;
337
    end
338
    else if (rd_SO) begin
339
        av_rd7 <= av_rd7; av_rd6 <= av_rd6; av_rd5 <= av_rd5; av_rd4 <= av_rd4;
340
        av_rd3 <= av_rd3; av_rd2 <= av_rd2; av_rd1 <= av_rd1; av_rd0 <= av_rd0;
341
        case (bit_count)
342
            0:  av_rd7 <= SO;
343
            1:  av_rd6 <= SO;
344
            2:  av_rd5 <= SO;
345
            3:  av_rd4 <= SO;
346
            4:  av_rd3 <= SO;
347
            5:  av_rd2 <= SO;
348
            6:  av_rd1 <= SO;
349
            7:  av_rd0 <= SO;
350
            default: begin
351
352
353
                    end
354
        endcase
355
    end
356
    else if (CS && state >= 1) begin
357
358
359
    end
360
    else begin
361
362
363
    end
364
365
end
366
367
368
369
always@(posedge  clock_sink_clk or negedge reset_sink_reset) begin      // DESASOCIAR BIT_COUNT DE CYCLE COUNTER
370
371
        bit_count <= 0;
372
    else if (word_ak)
373
        bit_count <= 0;
374
    else if (f_bit_count)
375
        bit_count <= bit_count + 4'b1;
376
    else
377
        bit_count <= bit_count;
378
end
379
380
381
382
383
        cyc_count <= 0;
384
    else if (f_cyc_count)
385
        cyc_count <= cyc_count + 4'b1;
386
    else
387
        cyc_count <= 0;
388
end
389
390
391
392
        byte_count <= 0;
393
394
        byte_count <= 0;
395
    else if (clear_byte_c)
396
        byte_count <= 0;
397
    else if (word_ak)
398
        byte_count <= byte_count + 4'b1;
399
    else
400
        byte_count <= byte_count;
401
end
402
403
//////////////// Controls enable from write and read /////////////////////
404
405
406
407
        enable <= 0;
408
    else if (avalon_slave_write || avalon_slave_read)
409
        enable <= 1;
410
    else
411
        enable <= 0;
412
end
413
414
////// controls write vs read order, with priority write /////////////////
415
416
417
418
        wr_mode <= 0;
419
    else if (avalon_slave_write)
420
        wr_mode <= 1;
421
422
        wr_mode <= 0;
423
    else
424
        wr_mode <= wr_mode;
425
end
426
427
428
429
430
        comm_in <= rd_comm;
431
432
        comm_in <= wr_comm;
433
    else if (avalon_slave_read)
434
        comm_in <= rd_comm;
435
    else
436
        comm_in <= comm_in;
437
end
438
439
440
441
        addr_in <= 0;
442
    else if (avalon_slave_write || avalon_slave_read )
443
        addr_in <= avalon_slave_address;
444
    else
445
        addr_in <= addr_in;
446
end
447
448
449
450
451
452
        av_wrdata <= 0;
453
454
        av_wrdata <= avalon_slave_writedata;
455
    else
456
        av_wrdata <= av_wrdata;
457
end
458
459
460
461
462
463
        data_in <= avalon_slave_writedata [7:0];
464
    else
465
    case (byte_count)
466
        0:  data_in <= av_wrdata [7:0];
467
        1:  data_in <= av_wrdata[15:8];
468
        2:  data_in <= av_wrdata [23:16];
469
        3:  data_in <= av_wrdata [31:24];
470
        default: data_in <= av_wrdata [7:0];
471
    endcase
472
473
end
474
475
476
477
///////// Gather all 4 bytes in 1 register ////////////////////////
478
479
480
481
        av_rd_byte1 <= 0; av_rd_byte2 <= 0; av_rd_byte3 <= 0; av_rd_byte4 <= 0;
482
    end
483
    else if (clear_byte_c && state >= ST_10) begin
484
        av_rd_byte1 <= av_rd_byte1; av_rd_byte2 <= av_rd_byte2; av_rd_byte3 <= av_rd_byte3; av_rd_byte4 <= av_rd_byte4;
485
        case (byte_count)
486
            0:  av_rd_byte1 <= av_rd_buff;
487
            1:  av_rd_byte2 <= av_rd_buff;
488
            2:  av_rd_byte3 <= av_rd_buff;
489
            3:  av_rd_byte4 <= av_rd_buff;
490
            default: begin
491
492
493
                    end
494
        endcase
495
    end
496
497
498
    end
499
end
500
501
502
endmodule
The top module is this
       module FLASH_CTL_TOP (
        input   wire    sys_rst,           //   reset_sink.reset
        input   wire    sys_clk,             // clock_sink_1.clk
        input wire SO,
        output wire SI,
        output wire CS,
        output wire WP,
        output wire HOLD,
        output wire SCLK ,
        output reg led
        reg [23:0]  avalon_slave_address;// avalon_slave.address    ?????????????????????????
        reg [3:0]   avalon_slave_byteenable;    //             .byteenable
        reg avalon_slave_read;          //             .read
        reg avalon_slave_write;         //             .write
        reg [31:0]  avalon_slave_writedata;     //             .writedata
        reg [14:0] tb_count;
        wire [31:0] avalon_slave_readdata;      //             .readdata
        wire avalon_slave_readdatavalid; //             .readdatavalid
        wire avalon_slave_waitrequest;   //             .waitrequest
        wire debugaccess, burstcount;
30
31
32
        reg [31:0] led_counter;
33
34
35
36
37
38
39
40
    flash_qsys u0  (
41
        .clk_clk             (sys_clk),             //   clk.clk
42
        .reset_reset_n       (sys_rst),       // reset.reset_n
43
44
        .end_cs              (CS),              //   end.cs
45
        .end_si              (SI),              //      .si
46
        .end_so              (SO),              //      .so
47
        .end_wp              (WP),              //      .wp
48
        .end_sclk            (SCLK),            //      .sclk
49
        .end_hold            (HOLD),            //      .hold
50
51
        .sobus_waitrequest   (avalon_slave_waitrequest),   // sobus.waitrequest
52
        .sobus_readdata      (avalon_slave_readdata),      //      .readdata
53
        .sobus_readdatavalid (avalon_slave_readdatavalid), //      .readdatavalid
54
55
        .sobus_burstcount    (burstcount),    //      .burstcount
56
        .sobus_writedata     (avalon_slave_writedata),     //      .writedata
57
        .sobus_address       (avalon_slave_address),       //      .address
58
        .sobus_write         (avalon_slave_write),         //      .write
59
        .sobus_read          (avalon_slave_read),          //      .read
60
        .sobus_byteenable    (avalon_slave_byteenable),    //      .byteenable
61
        .sobus_debugaccess   (debugaccess)    //      .debugaccess
62
63
64
65
66
67
FLASH_CTL FLASH_CTL_inst1 (
68
.SO (SO),
69
.SI (SI),
70
.CS(CS),
71
.WP(WP),
72
.HOLD(HOLD),
73
.SCLK(SCLK),
74
75
.avalon_slave_address (avalon_slave_address),
76
.avalon_slave_byteenable (avalon_slave_byteenable),
77
.avalon_slave_read (avalon_slave_read),
78
.avalon_slave_write (avalon_slave_write ),
79
.avalon_slave_writedata (avalon_slave_writedata),
80
.reset_sink_reset (sys_rst),
81
.clock_sink_clk (sys_clk),
82
83
.avalon_slave_readdata (avalon_slave_readdata),
84
.avalon_slave_readdatavalid (avalon_slave_readdatavalid),
85
.avalon_slave_waitrequest (avalon_slave_waitrequest)
86
87
88
89
90
always@(posedge sys_clk or negedge sys_rst) begin
91
    if (~sys_rst) begin
92
        led <= 1;
93
        led_counter <= 0;
94
    end
95
    else if (led_counter == 31'd100_000_000) begin
96
        led <= 0;
97
        led_counter <= led_counter + 16'b1;;
98
    end
99
    else if (led_counter == 31'd200_000_000) begin
100
        led <= 1;
101
        led_counter <= 0;
102
    end
103
104
    else begin
105
        led <= led;
106
107
    end
108
end
109
110
111
112
113
    if (~sys_rst) begin
114
        avalon_slave_read <= 0;
115
        avalon_slave_write <= 0;
116
        avalon_slave_address <= 0;
117
        avalon_slave_writedata <= 0;
118
        avalon_slave_byteenable <= 0;
119
    end
120
    else if (tb_count == 200) begin
121
        avalon_slave_write <= 1;
122
123
        avalon_slave_address <= 24'b0000_0000_0000_0000_0000_0011;  //// 24'b0000_0000_0000_0000_0000_0011
124
        avalon_slave_writedata <= 32'b1010_1010_1010_0000__0000_0000_0000_0011; //8'b1000_0101
125
        avalon_slave_byteenable <= 4'b1111;
126
127
    end
128
    else if (tb_count == 2000) begin
129
        avalon_slave_read <= 1;
130
131
132
        avalon_slave_writedata <= 32'b0000_0000_0000_0000__0000_0000_0000_0000; // 8'b0000_0000
133
134
    end
135
    else begin
136
137
138
139
140
141
    end
142
end
143
144
always@ (posedge sys_clk or negedge sys_rst) begin
145
    if (~sys_rst)
146
        tb_count <= 0;
147
    else if (tb_count == 3000)
148
        tb_count <= tb_count;
149
    else
150
        tb_count <= tb_count + 15'b1;
151
end
152
153
154
155
156
157
endmodule
The code is basically running as expected (as far as I know) as it can
be seen in the second attached imag, but I'm receiving this "1" from the
SO pin from the beginning of the time without changes, so I'm not able
to pick up the "supposedly" data from SO.
any thoughts about this? Chip might be malfunctioning?
  • [vhdl]VHDL-Code[/vhdl]
