Pulsing a pin of the PIC24F04KA201
Guest #5329472
Hello people. :-)
I am a beginner in the world of micro-controllers. I have the
PIC24F04KA201 and I have been trying to pulse an LED using the internal
clock of the microcontroller.
Here is the code that I have been using.
 * File:   newmainXC16.c
 * Author: Soumojit Bose
 * Created on February 24, 2018, 8:52 PM
#include <p24F04KA201.h>
#define FOSC 32000000
#define FCY (FOSC/2)//This is generally crystal frequency divided by 2
#include <libpic30.h>
#include<xc.h>
/*  *** Configuration Bits Setting  *** */
_FGS(GWRP_OFF & GCP_OFF)
_FOSCSEL(FNOSC_PRI & IESO_OFF)
_FOSC(POSCMOD_HS & OSCIOFNC_ON & POSCFREQ_HS & FCKSM_CSDCMD)
_FWDT(WINDIS_OFF & FWDTEN_OFF)
_FPOR(BOREN_BOR2 & PWRTEN_OFF & BORV_18V & MCLRE_ON)
_FDS(DSWDTEN_OFF)
30
31
//void Delay(unsigned int a);
32
int main()
33
34
35
36
    TRISBbits.TRISB0 = 0;       /*  Making Pin as output                            */
37
38
    LATBbits.LATB0 = 0;         /*  Writing zero to pin 0 of port A                 */
39
40
    while(1)
41
42
        LATBbits.LATB0 = ~LATBbits.LATB0;   /*  toggling state of PIN zero to one and vice versa    */
43
        __delay_ms(10); // this is actual delay time in msec
44
45
46
    return 0;
47
What I do not understand is how to set the OSCCCON bits so that I can
use the internal clock of the PIC24 to do my LED pulsing. Will the
_delay_ms() function work in the same way, if I use an external clock?
#5329493
Also attached here is the Proteus simulation. I have a configuration
where I am trying to pulse the RB0 pin of the microcontroller. At first,
I did not have CLKI and CLK0 grounded, assuming that my configuration
bit settings had taken care of it. The simulation did not work. When I
have the CLKI and CLKO pins grounded, the simulation works.
Am I looking at this the right way? Are my configuration bits wrong and
the internal oscillator (32 MHz) is not being used? If so, please help
me.
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
