Forum: ARM programming with GCC/GNU tools Display registers value - ARM assembly
von Ab A. (abanel88)
Hi there,
I was wondering If anyone can help me with this. I want to print or
write to a file and save the values of the registers running a simple
Hello world program for example. Can somebody guide me what I need to
know so I can do that? Or print to the monitor the values for example of
the R0-R4?
Any help or thoughts? Can I do this combining C or C++?
Many thanks!!
von M.K. B. (mkbit)
You should explain what you want to achieve with your dump of the
registers. Maybe you try to achieve something else where a different
approach is more suitable.
Since you are talking about C, C++ the registers are assigned by the
compiler  so each little change in the code or compiler settings might
lead to the same data being stored in a different register. Only by
writing assembler you can control directly which register you use.
Basically you can dump the registers using a debugger by single stepping
through the assembler instructions and copy the current register value.
Keep in mind that a simple looking prinft/cout contains lots of
assembler instructions which might use your registers.
